Author Topic: 1967 flasher brackets  (Read 518 times)
Offline wils1514
« on: March 24, 2021, 10:37:25 PM »
Looking for the flasher brackets that are mounted behind the instrument cluster that hold the turn signal and emergency flasher bulbs.
1967 Mustang fastback- build date: dec 23 1966-Metuchen
Re: 1967 flasher brackets
« Reply #1 on: March 27, 2021, 09:09:51 AM »
Do you know that your 67 had two brackets? A lot of the 67 had only one bracket. The other flasher a Tung Sol blue colored flasher had a twist lock fastener that locked in to a hole in the back of the instrument cluster.
I will look and see if I have any brackets.
Offline wils1514
« Reply #2 on: March 27, 2021, 05:01:17 PM »
I guess I'm not sure if it did or not. I've never had them since owner the car (20 years). I'll have to look into if it did or not? Thanks for the help!
« Last Edit: March 27, 2021, 06:38:37 PM by wils1514 »
