Author Topic: Motor Mount Metal/Frame Brackets. For 1968 428CJ  (Read 351 times)
Offline Craners
« on: January 07, 2023, 09:25:32 AM »
Wanted: Searching for motor mount frame to motor brackets for 1968 428 CJ.(not the rubber mounts)
Restorable units (no rust pits)
Thank you
Fran
I have sourced the brackets. 1/25
No longer looking..
Thks
« Last Edit: January 25, 2023, 07:46:05 PM by Craners »
Re: Motor Mount Metal/Frame Brackets. For 1968 428CJ
« Reply #1 on: January 07, 2023, 11:26:28 AM »
There are two sets of brackets, the brackets from the rubber mounts to the engine block and also, the ones from the rubber mounts to the frame.
If I understand you correctly, you need just the ones from the rubber mounts to the frame.
ONLY in 67 production, these are the same on 289 engines.
Many people needing new 67-only rubber motor mounts THAT ARE NOT REPRODUCED, end up changing the frame brackets to the 68-up type.
This can be another (more affordable) way to find them.
Good luck in your search...those who KNOW, know this and those who DO NOT, often sell at a very reduced price ;)
Offline rustbucket
« Reply #2 on: January 07, 2023, 01:14:40 PM »
I believe there are 3 sets of brackets.
metal block brackets that bolt to the block and have 2 studs , intermediate rubber brackets and frame brackets that bolt to the frame.
and I think he mentioned he did NOT need the rubber brackets.
I may have a set of frame brackets , let me check
