Author Topic: Heater Hose Straps 66 289 4V SJ  (Read 3525 times)
Offline 1966GTFB
« on: June 29, 2015, 01:16:43 PM »
I am wondering about the heater hose straps. I have the routing in place but what holds these up off the valve covers and together, etc? I read lots about the strap on the 6s, is it the same for my car?
1) What straps should I be using or have and
2) Can you get them anywhere these days?
I have an early Sept 65 built SJ 4V.
Any pictures would be great.
Jeff
« Last Edit: June 29, 2015, 03:59:20 PM by J_Speegle »
SJ Build Date: 9/17
'66 Fstbk: 63A X 26 17J
Re: Heater Hose Straps 66 289 4V SJ
« Reply #1 on: June 29, 2015, 03:34:11 PM »
IMHO no straps - the heater hoses are meant to run along the top of the valve cover/side of the intake to their connection points on the intake manifold and water pump
Is this a Thermactor equipped car?
If you had AC then there would be a strap for that hose on the drivers side - metal style one
« Last Edit: June 29, 2015, 04:03:33 PM by J_Speegle »
Offline 1966GTFB
« Reply #2 on: June 29, 2015, 04:30:48 PM »
No Thermactor. So no straps (Zap straps  ;)) holding the 2 hoses to one another?
Thanks again Jeff.
Jeff
SJ Build Date: 9/17
« Reply #3 on: June 29, 2015, 04:52:11 PM »
No Thermactor.
Nope - no straps, zip ties, duct tape holding the two heater hoses together. If you route them (top one) under the PCV hose and both under the spark plug wires and don't cut them so they are too long they stay in place and neatly
Offline rockhouse66
« Reply #4 on: June 29, 2015, 07:00:35 PM »
One runs through the clip on the carburetor.
'66 GT FB
« Reply #5 on: June 29, 2015, 08:18:07 PM »
The hot water from the engine runs past the choke to keep it open, except HP engines.
Offline Brian Conway
« Reply #6 on: June 29, 2015, 08:58:53 PM »
    65 289.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #7 on: July 04, 2015, 06:37:37 PM »
    65 289.  Brian
Those heater hoses do not appear to be routed correctly.  The hose that goes through the bracket at carb should connect to the intake.
« Reply #8 on: July 04, 2015, 07:31:27 PM »
     Interesting that the shop manuals for 65 and 66 show different routes.  I elected to go with the 66 route.  Brian
San Diego, Ca.
