Author Topic: 66 Jan built NJ Engine Detailing  (Read 8669 times)
Offline rrenz
« on: May 04, 2016, 09:26:19 PM »
I picked up my 66 C Code jan Metuchen just over a year ago. Ive begun sort of a Driver restoration trying to keep as authentic as possible yet safe and reliable. Im about to start showing the car and would like to see if anyone has any suggestions for anything I'm missing or should change. Ive started with the engine and I'm working my way into the interior now.
Should I Have a paint ok decal on the cowl?
I believe i also have the wrong autolite spark plug decal however i need to repaint the air cleaner. was not painted with the block
« Last Edit: May 06, 2016, 05:49:19 PM by J_Speegle »
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline tomtri66
  • Bronze Level Subscriber
Re: 66 Engine Detailing
« Reply #1 on: May 04, 2016, 09:42:20 PM »
I'm no expert by any means and I will defer to those in these forums who are, but one thing I see is that the coolant bypass hose and clamps were painted with the block so therefore would be engine blue.  Also, I believe there was some discussion that Metuchen was using the stapled wire type upper radiator hose clamps at this time but I'm not sure what the consensus was.
No paint OK decal on the cowl but paint Ok stamps are correct on cowl, inner fenders, and bottom side of hood.  There are threads discussing that topic.
Hood hinges should be phosphate and oil and not painted.
Master cylinder should be blacked out.
Nice looking car!  My car is also a Jan Metuchen hardtop.  Would love to compare notes :)
« Last Edit: May 04, 2016, 09:56:28 PM by tomtri66 »
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #2 on: May 04, 2016, 09:53:10 PM »
I don't recognize the white sticker on top of the radiator support, halfway between the center and the driver's side fender.
Offline tomtri66
« Reply #3 on: May 04, 2016, 09:57:10 PM »
+1.  I wasn't sure about that either.
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Offline ChrisV289
« Reply #4 on: May 04, 2016, 10:15:19 PM »
Spacer should be steel color and not gold as that was reserved for the hi-po motors.  I think the bottom of the fuel line clamp on the water pump should also be painted blue.  Also I believe the heater hose that attaches to the water pump is too long and should be routed along the top of the manifold...Vacuum advance line should be steel not a rubber hose..Plug wires on the driver side need to be in this order from the front to back; 7,5,6,8
« Last Edit: May 04, 2016, 10:19:37 PM by ChrisV289 »
2009 V6 Mustang Coupe
« Reply #5 on: May 05, 2016, 12:30:29 AM »
Alternator spacers in 1965 were made from a round steel bar with a hole for the 7/16 inch bolt, all spacers in 1966 were a gold finished aluminum extrusion with a bolt hold and a slot.
It's the wrong style vacuum advance, hence the rubber hose.
Offline rrenz
« Reply #6 on: May 05, 2016, 10:31:02 AM »
That is the rotunda anti freeze decal.
Ryan
C-4 Automatic
Build Date Jan 21st
Offline rrenz
« Reply #7 on: May 05, 2016, 10:34:06 AM »
Alternator spacers in 1965 were made from a round steel bar with a hole for the 7/16 inch bolt, all spacers in 1966 were a gold finished aluminum extrusion with a bolt hold and a slot. It's the wrong style vacuum advance, hence the rubber hose.
Thanks for clearing that up. I was getting worried. I actually have a steel spacer I took out to replace with the gold.  And yes my advance was replaced by the previous owner. That's on the list yet ..
Ryan
C-4 Automatic
Build Date Jan 21st
Offline AU SNK
« Reply #8 on: May 05, 2016, 11:01:45 AM »
I have an April 66 NJ "survivor' FB and the Paint OK stamp is located right above the brake master cycl on the cowl. It also has the gold spacer
Unrestored 66 Metuchen, NJ Fastback 6T09C2435XX
Sauterne Gold Metallic, Lt. Ivy Gold Crinkle Vinyl and White Crinkle Vinyl, Pony Interior
Offline Hipo giddyup
« Reply #9 on: May 05, 2016, 11:18:57 AM »
First of all, this is an EXCELLENT driver, very nice!! If you really want to go further done the "concours road" I'll throw in some other findings that i think are correct from all of my findings on this site. Of course the others are dead on and will surely chime in if I'm wrong.. ;D
1. Battery tag under positive cable.. I believe this is usually removed?? there are some other threads on this.
2. Shock tower cover bolts, hood hinge bolts, hinge to hood bolts should be phosphate and oil, they look to be painted. The shock and shock cap bolts themselves were cadmium I think??
3. Undercoating around heater motor, main harness plug on firewall(next to master cylinder). Some folks go this far to duplicate what was done at the factory level and I believe this was at all Ford plants?
4. I think there should be a stamping on the alternator?
Offline Building 3
« Reply #10 on: May 05, 2016, 11:30:49 AM »
October 1965 Metuchen build for me. Unrestored, but of course serviced over the last 50 years. I too have the gold spacer and the "Paint OK" yellow paint stamp above the master cylinder on the cowl. The inspector was "Adam." The only intact decal in the engine compartment was the silver service one located on the driver side  inner fender apron. There were some glue remnants and outline for the "289" decal on the air cleaner and maybe a bit of glue on the driver side of the air cleaner for the Autolite decal, but maybe or maybe not on that one. No other remnants that I could find. Hood hinges are phosphate and oil, steel vacuum advance line.  That's all that I can verify with my car.  If you do a search you will find, as I did, that the master cylinder/cap/booster were all painted semi-gloss black as a unit by the supplier, that coolant decal has no resolution, maybe yes, maybe no; coolant bypass and clamps painted with the block so blue. You should check the assembly manual for the proper routing of the coolant hoses. If you don't have one I made a simple diagram. I got that wrong at my first show on my other car so I tripled checked it to make sure I got it right. There are lots of posts on the firewall sound deadener spray so if you go that route be sure to check out the many photos. Of course you want to make sure you are duplicating the Metuchen process if it differed from the other plants. Lots of previous posts you can search.  Have fun! You have a very nice car. I am sure we'd all like to see more photos.
« Reply #11 on: May 05, 2016, 02:54:30 PM »
Curious, being a Metuchen built car, do you have the metal body buck tag that goes on top of the firewall near the hinge, driver's side??
Offline sgl66
« Reply #12 on: May 05, 2016, 03:10:33 PM »
Check this thread for more about paint ok stamps http://www.concoursmustang.com/forum/index.php?topic=6230.msg35359#msg35359
Mine is also an October 65 Metuchen build. It seems that Metuchen has a reputation for being consistently inconsistent and to further support that, my PAINT OK (by VENTRIGLIA) is on the passenger side of the cowl and the buck tag is on passenger side also.
Offline rrenz
« Reply #13 on: May 05, 2016, 06:04:25 PM »
thanks so much. yes I've been going through and replacing bolts here and there. i need new shocks so that will be next. thanks for the input on the undercoating. Ive been unsure about that. Ive also been looking high and low for an alternator stamp however haven't run across one for my particular setup.
Ryan
C-4 Automatic
Build Date Jan 21st
Offline rrenz
« Reply #14 on: May 05, 2016, 06:09:51 PM »
thanks for the comments. This car was a bit of a basket case when i got it. its been a challenge. the input is much appreciated.
Ryan
C-4 Automatic
Build Date Jan 21st
