Author Topic: '66 hood letter installation with no holes present  (Read 3786 times)
Offline socalgt
« on: May 10, 2017, 10:35:22 PM »
I'm assuming it's a big job to install F O R D on a hood that has had the holes filled in......I assume there isn't a ready made templet available for the holes.  I don't want to use reproduction letters, so I thought about cutting the points off original letters and maybe using silicone.  Are the points visible from the backside of the hood on original letters?  I don't have a car in my possession currently to look at.
Offline socalgt
Re: '66 hood letter installation with no holes present
« Reply #1 on: May 10, 2017, 10:51:32 PM »
I found a good article in Mustang Monthly about just this....shows the position of the letters very clearly in pictures using a sewing tape measure.  Article titled "How to pin letters on '65-'68 Mustang".
Offline Hipo giddyup
« Reply #2 on: May 11, 2017, 11:56:42 AM »
I do believe a  few of the pins can be seen from underneath when looking into the access holes. I have used another hood as a template with using masking tape, marking the holes with an awl through the tape, then transferring the masking tape "template" and matching it to the new hood. Has worked well for me in the past. I realize not everyone has a spare hood lying around.  :(
Offline socalgt
« Reply #3 on: May 11, 2017, 02:57:54 PM »
Sounds like a good method...if, as you say, you have an extra hood.  The article was very detailed with the placement of each letter, so I'll plan on using it.
Offline drummingrocks
« Reply #4 on: May 11, 2017, 04:45:07 PM »
If the holes have been filled in, I would worry about possibly disturbing the filler if you tried to re-drill the holes.  If it doesn't have to look completely original from the underside of the hood, have you thought about going with adhesive-backed letters?
« Reply #5 on: May 11, 2017, 05:30:40 PM »
« Reply #6 on: May 11, 2017, 06:45:09 PM »
Still beats trying to drill a freshly-painted panel, with unknown body filler underneath.  Drill could slip, drill could walk, etc.
Offline socalgt
« Reply #7 on: May 12, 2017, 07:35:27 PM »
That's certainly something to consider....Thanks
Offline socalgt
« Reply #8 on: May 13, 2017, 09:11:44 AM »
I found that with the hood edge trim removed you can see all the holes (filled in) for all four letters, so I can open them back up carefully and reinstall the letters.  I'll start with the smallest possible drill and work my way up.
Offline 1966KGT
« Reply #9 on: May 14, 2017, 08:41:04 AM »
drill filled in holes from behind that are visible, lessening the risk of bit walking, then possibly make a template with tape using what holes were able to be drilled then with tape on outside drill others? if several can be drilled from behind you may be able to get an idea of positioning others. just my two cents worth. would the barrel nuts possibly still be in filled in holes?
1966 K GT, BUILT 11/08/65 4 SPEED, SAN JOSE CAR, 1969 Mustang convertible, 1970 MACH 1, 1963 GALAXIE Q code Fastback, 1966 mustang t code coupe, fuel injected
Offline Dodger Tom
« Reply #10 on: May 21, 2017, 03:31:57 PM »
What is the hole size for the FORD hood letters?
« Last Edit: May 21, 2017, 03:51:53 PM by Dodger Tom »
Offline racincast
  • may 65 FB Metuchen
« Reply #11 on: February 07, 2025, 06:57:47 PM »
Almost sure sawing some measurements to FORD letters on hood. Searching for that post for some time now and can't find it. Please let me know where it is.
Thanks in advance
Jose
Fastback GT 5T09A16XXXX
WIMBLEDON WHITE
Bright Red Interior
