Author Topic: Gold air cleaner and valve covers....normal?  (Read 1845 times)
Offline tvtommy
« on: May 25, 2017, 08:07:21 PM »
Thanks for checking this out.
I'm looking to purchase a '65 convertible. The air cleaner and valve covers are gold in color....is that normal?
Thanks in advance!
« Last Edit: May 25, 2017, 11:37:01 PM by caspian65 »
'67 Lime Gold Coupe - Rescued in 2006
'65 Wimbledon White Convertible
Re: Gold air cleaner and valve covers....normal?
« Reply #1 on: May 25, 2017, 08:24:05 PM »
yes it is.
Offline tvtommy
« Reply #2 on: May 25, 2017, 08:42:55 PM »
Thank you sir, this is a new learning process, a step up from my '67 T code coupe.
« Reply #3 on: May 26, 2017, 12:42:51 AM »
What engine?
Offline tvtommy
« Reply #4 on: May 26, 2017, 11:14:11 AM »
C code 289.
Offline mjd 65
« Reply #5 on: May 26, 2017, 07:36:42 PM »
A 65 289 should have a black block, with gold valve covers and air cleaner. The gold color was a deeper shade in early 65, and became lighter by late 65.
Mel
Offline tvtommy
« Reply #6 on: May 26, 2017, 08:53:19 PM »
So if I'm seeing a different '65 C code with blue block, air cleaner and valve covers = not correct?
« Reply #7 on: May 26, 2017, 09:01:34 PM »
yep....not correct.
Offline ChrisV289
« Reply #8 on: May 27, 2017, 11:45:35 AM »
Either they repainted the motor wrong or that is a motor out of a 66.
2009 V6 Mustang Coupe
« Reply #9 on: May 27, 2017, 12:22:11 PM »
You may be able to tell the engine assembly date by looking at the left hand front of the block by the distributor at an extension used for attaching a water pump bolt. See pictures. The numbers are stamped into this extension by the inspector (or the assembly guy) in this format, 5H23Z: year - 5; month - H (January is A); day - 23; inspector - Z. The assembly date should precede the scheduled build date (from the door data tag) by at least a week (more likely longer). Post the car's VIN (use xx in the last two numbers for security) and we should get you close to that date.
Offline tvtommy
« Reply #10 on: May 27, 2017, 09:57:55 PM »
OK...
5F08G806xxx
I looked it over today, and I think I'll grab it....a nice stable mate for the lime gold '67.
Thanks in advance!
Offline drummingrocks
« Reply #11 on: May 28, 2017, 11:28:05 AM »
OK...
5F08G806xxx
Thanks in advance!
Might want to double check the VIN.  There shouldn't be a G in the 5th digit for a '65 model.
Edit: Just saw where you said it was a C-code motor.  I'm guessing the G was a typo and should have been a C.
Offline tvtommy
« Reply #12 on: May 28, 2017, 05:17:04 PM »
Yes...that should be a "C".
