Author Topic: 70 Dearborn (Dec 69 build) fender bolts  (Read 4574 times)
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« on: December 27, 2017, 03:45:18 PM »
I am looking to see if someone with either an original car or well documented, can tell me the bolts that are used on their fenders, Dearborn Dec 3 1969 time zone.  Here a re six bolts I put together, not sure if any of these were used at that time period or not.  Any input appreciated.  Thanks!
« Last Edit: January 25, 2018, 05:10:30 PM by J_Speegle »
MCA#31064
Re: 70 fender bolts
« Reply #1 on: December 27, 2017, 04:58:05 PM »
Armond,
Off hand, yes. Fender bolts with those head markings look "appropriate". However, most of the Mustangs I see on the West coast are San Jose built.  The underside of the washer should be smooth, no "teeth".
Offline Armond
Re: 70 fender bolts
« Reply #2 on: December 27, 2017, 05:06:38 PM »
Yes thanks Jim,  I am just trying to narrow it down closer to when this car was built, hoping someone has one close.   It is for a Boss 9 I am restoring so I am being more neurotic about this one.
MCA#31064
Re: 70 fender bolts
« Reply #3 on: December 27, 2017, 06:03:09 PM »
Armond will look through my picture collection focusing on the 0F140000 range and report back
« Last Edit: December 27, 2017, 06:17:00 PM by J_Speegle »
Offline Armond
Re: 70 Dearborn fender bolts
« Reply #4 on: December 27, 2017, 08:20:35 PM »
Thanks Jeff!
MCA#31064
Offline PerkinsRestoration
« Reply #5 on: December 27, 2017, 11:58:35 PM »
One and five are typical. Armond, send me your shipping address I've got the panel boxed up.
Offline Armond
« Reply #6 on: December 28, 2017, 01:48:39 AM »
Thanks Bob!  Message sent to your email.
MCA#31064
Offline Mike Bauman
« Reply #7 on: December 28, 2017, 02:40:35 PM »
Hi,
My Dearborn Boss 302 0F119XXX, October 13, 1969 build date had bolt number five in most fender bolt locations, with a few large washered SEMS thrown in here and there. Hope this helps!
Mike
« Reply #8 on: December 28, 2017, 04:25:42 PM »
From the picture, types 1, 3, 5 and 6 are grade 5.1, types 2 and 4 are not. Conventional wisdom has indicated the grade 5.1 fender bolts were used by Ford from 1968 on.
Offline Armond
« Reply #9 on: December 28, 2017, 05:50:46 PM »
Thanks for all the input! Just what I needed.
MCA#31064
« Reply #10 on: December 28, 2017, 07:28:35 PM »
Bolt head design #1 (small flags)  & #5 (circle L's) were were the ones I found were used in the 140000-150000 range in 1970 production at Dearborn
On my best example there was a mix on the fender attachment.
On the spring cover/shield attachment I found all #5's
« Reply #11 on: December 28, 2017, 08:24:02 PM »
And all appear to be Grade 5.1.
As specified, they should be cad plated. As cad plating is falling out of favor, try a dull zinc finish after bead blasting.
« Last Edit: December 28, 2017, 08:38:31 PM by jwc66k »
Offline Armond
« Reply #12 on: December 28, 2017, 09:51:31 PM »
Thanks for the pictures and your time looking Jeff.  It looks like I am going to go with #5.   Thanks for all the help guys!
MCA#31064
Offline bgp429
« Reply #13 on: December 28, 2017, 09:55:55 PM »
On one of the threads at the Boss site there was a discussion about B9's having different fender bolts than regular production. Reason was the fenders were removed at Kar Kraft and reinstalled. I paid attention to it because in my ignorance I tossed the original bolts out.
Link shows a RSC bolt. There are several threads on the subject. Sent E mails to AMK, they weren't interested in reproducing them. Potential sales would be too small.
http://www.boss302.com/smf/index.php?topic=58366.msg379704#msg379704
« Last Edit: December 29, 2017, 12:21:57 AM by bgp429 »
« Reply #14 on: December 29, 2017, 05:24:29 AM »
The RSC bolts were also used for a short period on non- Boss 9 cars also but not during the period asked about
