Author Topic: Correct paint for suspension components, transmission cross brace etc..66 NJ K  (Read 4032 times)
Online CharlesTurner
Try using evapo-rust, has been discussed here on the forum previously.  Works well at removing all rust and turning up any markings.
Thank you all for the comments.  This site has been very helpful and I am grateful!
Remember to redo the fresh machined surfaces. Example would be the spindle. Visible one the car is assembled will be the ball joint attachment, bump stop and the tie rod attachment surfaces. Not certain at the moment if the surfaces where the caliper mount or backing plate bolts pass through are visible. There is typically a spot where the finish will have been ground down and the metal tested so that would be brighter there also
Though its from a different year there is one attempt to reproduce the differences in finish
« Last Edit: February 05, 2018, 05:54:31 PM by J_Speegle »
Offline evantugby
Oh wow!  Well I need to do that.  What method are people using to recreate these machine surfaced finishes?
To quickly get the metal clean, roto-discs on a die grinder work well, then followed by a level block sander or stick.
Offline evantugby
how about this?  haha.  Just went out to the garage and did it.  Never used a level block sander.  Can you provide a recommendation?
« Last Edit: February 05, 2018, 10:45:29 PM by evantugby »
The issue with using a die grinder by itself is it will create inconsistent patterns and possibly round edges.  Doing a final sand with something flat will give a more correct, 'freshly cut' appearance.
++1 Without the final step it will be notably different from what was originally done
Offline evantugby
which level block sander are you using?  I want to make sure I get this right.  I'm enjoying this restoration process and learning a great deal from you experts!
Just something flat to wrap sandpaper around is fine, it's nothing technical.  Paint sticks work well.
Offline evantugby
Gents,
Follow-up question:  How about the rear backing plates?  I have them completely sand blasted.  Do they get a semi-gloss black like the front backing plates?
Also, do these backing plates look original?  Both have FOMOCO but  one says Bendix 17564L and the other is so lightly stamped I can't read it.
« Last Edit: February 14, 2018, 02:55:16 PM by evantugby »
yes they are s/g black. look a little pitted though. have you seen charles turner's blog regarding a hi-poo he did several years ago?
Offline ChrisV289
Did you find any white slash marks near the adjustment hole?  Don't know if it was just a San Jose thing or if the other plants did them
2009 V6 Mustang Coupe
These may be different size plates (different size rear brakes) different backing plates from what your working with Chris.
Also its not always that marking and not a San Jose detail IMHO.
We could get off into a complete thread on backing plates so will not go into greater detail here about 66 examples and the differences between cars and applications  ;)
Yes, lots of pitting there.  Would suggest epoxy prime both of them, let it dry and then tape over the FoMoCo and Bendix markings.  Cut as close to the markings as possible.  Then use a quality build primer, sand, re-prime if necessary and then paint semi-gloss black.
Offline evantugby
Does powdercoat hide imperfections well?  Or would you still use epoxy primer?
