Author Topic: 4 speed tailshaft seal assembly line style  (Read 630 times)
Offline cbrown
  • Silver Level Subscriber
« on: September 03, 2018, 11:06:16 AM »
I have a limited quantity of the rear  shaft seal for the big output 4 speed transmissions.  This is the assembly line style that is thicker and has the felt made in it as well as the rubber seal.  You can see the felt when assembled.    I am sure some of you all know how hard this seal is to find.
1 for 35$ plus shipping
2 for 60$  plus shipping.
chris
Re: 4 speed tailshaft seal assembly line style
« Reply #1 on: September 05, 2018, 08:42:14 AM »
The new seal has victor 49720 ID stamped on it even thou it isnt seen when installed correctly since the double seal type original seal has rubber seal inward & felt type outward when pressed in place. The service replacement & over the counter type seals are totally different & thats why we had this concours correct original type made. If u try and remove the original worn used seals u will damage them & cant be used over again.
