Author Topic: 65 Heater Riser / Shield  (Read 1029 times)
Offline ChrisV289
« on: July 01, 2019, 05:02:54 PM »
Anyone have a reasonably priced uncut heat riser / shield? Paint can be bad as I will repaint but no holes. Also if possible a date code of 5A to 5E
2009 V6 Mustang Coupe
Offline Hipo giddyup
Re: 65 Heater Riser / Shield
« Reply #1 on: July 02, 2019, 04:04:15 PM »
I have a few Chris. Where is the date code located on these??
Can't say I have identified that before.
Offline ChrisV289
« Reply #2 on: July 02, 2019, 05:31:08 PM »
It is on the side that faces out towards the bottom near the curve of the piece that goes up to the snorkel
« Reply #3 on: July 03, 2019, 09:28:08 AM »
Got it, never picked up on that. Let me take a look, I have at least two nice heat risers.
« Reply #4 on: July 03, 2019, 12:55:45 PM »
When I hear the term "Heat Riser", I think you are referring to a flap valve in the exhaust, thermostatically controlling the exhaust to force early engine warm-up by redirecting exhaust flow through the intake manifold exhaust passage.
I call the "heat shield" a heat shield and have heard it called a heat stove but terminology varies.
Fwiw, I call a Coca-Cola a "Coke" and a Pepsi a "Pepsi" but folks here in Ohio like to call them a "pop" and folks elsewhere call them a "soda" so what do I know ;)
« Reply #5 on: July 03, 2019, 01:50:28 PM »
No,  you are correct. I have heard heat riser from my Dad as in, heat rises to the air cleaner I guess? LOL
Online jwc66k
« Reply #6 on: July 03, 2019, 03:30:51 PM »
Ford calls the heat riser a "Shroud and Tube Assy" - C4OF-9A607-A, and a "Duct and Valve Assy" - C3AF-9A626-B. They are supposed to assist the engine rise to a good operating temperature along with the choke by ducting warm air into the carburetor. When the engine reaches it's optimum operating temperature, the choke is open from heat entering via the fitting on the RH exhaust manifold (289 engine), the flap valve closing off the warm air from the same fitting. In warm states, they operate quickly. In cold areas, it may take forever.
The exhaust version was not used (thankfully) in a 289.
« Reply #7 on: July 03, 2019, 08:08:26 PM »
Pm sent
« Reply #8 on: July 03, 2019, 09:51:40 PM »
Chris, the first one I came across has a stamping of 6M. I’m guessing far too late for what you need. I have another so I’ll rummage through my parts tomorrow to verify.
Offline ChrisV289
« Reply #9 on: July 03, 2019, 10:40:59 PM »
Thanks, Bill got me covered with a 5E date coded one.  I appreciate it though.  One piece down, many more to go for the blue one...
« Reply #10 on: July 04, 2019, 02:20:51 AM »
So glad we have members helping members. Just one more way the site helps get things done and brings us together.
Happy holiday and weekend to all
