Author Topic: Mounting Front chrome eyebrows 1969  (Read 1493 times)
Offline SCJSTU
« on: September 29, 2019, 10:47:10 PM »
Have one coming loose.......how do you get to backside to re attach?
2004 Mach 1 Azure Blue
Re: Mounting Front chrome eyebrows 1969
« Reply #1 on: September 29, 2019, 11:02:14 PM »
You have to go up though the backside of the fender 1/4 ratchet,long extension and socket . you have to take the front wheel/tire off to get in there to work.I haven't tried out my harbor freight borascope camera on something like this but I think it would help especially if you have never done it before to get the lay of the land so to speak.
« Reply #2 on: September 30, 2019, 12:22:34 PM »
is that camera any good??? considering purching similar item.......thanks
« Reply #3 on: September 30, 2019, 02:48:21 PM »
The one I have was cheap and work as designed. It was just the ticket for my occasional use. I am positive that there are much better ones out there at various prices but I have not had any reason to investigate other like cameras.
Offline 69GT350H
« Reply #4 on: September 30, 2019, 03:26:47 PM »
My eyebrows used threaded studs and nuts with built in flange washers. The eyebrow goes up against the fender on the outside, then the headlight bucket goes up against the fender on the inside. The stud has to thread into the eyebrow, pass through the fender and headlight bucket, then the nut goes on. There are 3 of these studs that hold each eyebrow on. As mentioned, it is a very tight area, hard to get to even with the fender off the car. Attached is the best image that I have that shows the 3 round holes for the studs. My headlight buckets were beaten up a little and I had to repair some of the holes where the studs went through as seen in the photo.
« Reply #5 on: September 30, 2019, 03:49:40 PM »
It is a difficult tedious job to replace a dented or rusty eyebrow on a 69/70 finished Shelby but it can and has been done by many of us . At least for me more times then I care to remember.
« Last Edit: September 30, 2019, 10:30:02 PM by Bob Gaines »
« Reply #6 on: September 30, 2019, 07:16:29 PM »
Agree it can be a paint - just not as dirty and greasy as some others I can think of.
Consider removing the front plastic splash shield and even the front metal shield attaching the outer front of the fender to the inner fender to improve greatly the access
