Author Topic: 1970 Mustang Exhaust Welds  (Read 1407 times)
Offline Cobrajetken
« on: January 31, 2020, 11:44:44 AM »
Can anyone tell me what the correct 1970 mach 1 exhaust installation is. Where were clamps used and where were welded connection used. From photos I’ve seen it looks like muffler inlet and outlet was welded to pipes and exhaust tips were welded. Two clamps at engine pipe to exhaust pipe and clamps at rear hangers. Total four clamps used. Does this sound right? Thanks.
Re: 1970 Mustang Exhaust Welds
« Reply #1 on: January 31, 2020, 12:42:18 PM »
Much of what you're asking about is documented in the "70 Mustang Chassis Assembly Manual" available at most Mustang parts sellers.
Offline Coralsnake
« Reply #2 on: January 31, 2020, 07:53:59 PM »
I dont think the factory welded exhaust pipes.
« Reply #3 on: January 31, 2020, 08:26:03 PM »
+1. Installed as a already welded together assembly.
« Reply #4 on: January 31, 2020, 09:44:17 PM »
This is for your 1970 Mach 1 Mustang 351 Cleveland 4V I'm guessing
The MPCs show the service replacement pipes and layout. They can differ from assembly line parts or be very similar. As mentioned the Assembly manuals show some of the applications
The H pipe is a series of three pipes welded together (70 San Jose M code Mach I)
Close-up of connection and index notch
Below are some examples from 70 Boss 302 which would be similar to your application - except for the back end of the pipes (tips)
The H pipe attaches to (with two clamps) to the intermediate pipes with mufflers (welded to one another by the supplier), One passenger and one drivers side pipe and muffler combinations
Back surface of the muffler is welded to the tail pipes. They differ depending on the application.
Muffler hanger example (70 San Jose M code Mach I)
Rear Mount and clamp (both sides) with gas tank behind (70 San Jose M code Mach I)
Different view of the clamp style and hardware
View of the passenger side (70 San Jose M code Mach I)
From there you have the shinny exhaust tips that are added to the ends that extend through your rear valance
What apparently I don't have or can't find at the moment is a picture of the hardware, location and how the tips were attached to the tail pipe- Sorry but hope this helps
« Reply #5 on: February 01, 2020, 04:03:19 PM »
You can also see the factor installation in the 65-72 Ford Car Parts (aka MPC) in this -
https://www.squarebirds.org/Manuals/1965/1965-72FordPartsTextCatalog/
Go to section 52.70 in the text section for drawings of the factory, and the service replacements.
I recommend you down load the entire MPC. It's consists of 45 fils, 430mb.
