Author Topic: 1967 GT500 Trunk Emblem Install  (Read 912 times)
Offline kkupec02
« on: August 23, 2020, 04:24:17 PM »
I couldn't find best practice anywhere during search. I assume that in order to install a new trunk emblem you have to take off the drivers side trunk hinge and maneuver through that hole?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: 1967 GT500 Trunk Emblem Install
« Reply #1 on: August 23, 2020, 06:03:50 PM »
The emblem is not held to the car with a set of nuts from the inside so no reason to remove the trunk lid for mounting
« Reply #2 on: August 23, 2020, 06:48:17 PM »
Nothing to take off from the backside because it was installed from the front side. Barrel nuts were used so that the emblem could be pushed on from the outside.A emblem can be carefully pried off without damage. I use one of the flat plastic trim removal tools like you see on ebay for like 10.00 for a set. https://www.ebay.com/itm/Car-Trim-Removal-Tool-Kit-Set-Door-Panel-Fastener-Auto-Dash-Plastic-Interior/372901874846
« Reply #3 on: August 23, 2020, 08:18:28 PM »
Emblems can also be removed from barrel nuts using dental floss slipped behind the emblem.
Offline kkupec02
« Reply #4 on: August 23, 2020, 10:21:04 PM »
Thanks. I just ordered the trim tool kit Bob recommended.
« Reply #5 on: August 23, 2020, 11:17:12 PM »
Harbor Freight also carries these also. If a location is close and you can find  or down load a 20% off - timing with a sale is also helpful they can be pretty inexpensive
Just a mention for others considering a purchase
