Author Topic: 64.5 wire clip under scuff plate (door sill)  (Read 724 times)
Offline midnite cruiser
  • midnite cruiser
« on: August 31, 2020, 03:16:49 PM »
July 64 car had 8 of these holding the wire runs under the scuff plates.
Most are cracked/missing. No luck finding P/N in the Osborn manuals.
Ribbed plug end same size as wire loop style under hood.
Is this reproduced?
JWhite
64.5 D code convert. / C4 / AC / PS / RP
Re: 64.5 wire clip under scuff plate (door sill)
« Reply #1 on: August 31, 2020, 04:40:04 PM »
The clip is shown in the 64 Electrical Assembly Manual (AM003 pg 18) as 377864-S. There are two uses for the clip, the door sill on the left for all cars, the door sill on the right for convertibles.
A different clip was used in 65 (379862-S), tape was used in 66.
All three applications are shown in the library in "Mustang Hardware Spreadsheets, 64-66".
It is not reproduced.
  • midnite cruiser
« Reply #2 on: August 31, 2020, 05:40:26 PM »
Thank you. I do see the numbers in the spreadsheet.
I will use some loop style wire holders so the holes are plugged then tape as needed.
JWhite
