Author Topic: 68 Mustang Seat Rail  (Read 473 times)
Offline Corey Bowcutt
« on: September 15, 2020, 11:52:53 AM »
One of the threaded studs that mount my driver's seat to the floor has damaged threads.  I am not sure if these threaded studs can be pressed out and replaced of not?  Does anyone out there have a spare seat rail with good studs or if the studs can be removed does anyone have any replacement studs?
Thank you,
Corey
Re: 68 Mustang Seat Rail
« Reply #1 on: September 15, 2020, 11:55:00 AM »
can you run a thread die over them & clean it up??
« Reply #2 on: September 15, 2020, 12:28:53 PM »
Run a 5/16' - 18 NC die over it. If that doesn't work you can buy one side or a whole assembly from WCCC:
https://secure.cougarpartscatalog.com/67tracksetbench.html?sessionthemeid=26
Thank you,
Corey
« Reply #3 on: September 15, 2020, 01:45:47 PM »
I think a good quality tap and die set is the most underrated item in the tool box.
« Reply #4 on: September 15, 2020, 02:02:19 PM »
That and a credit card.
« Reply #5 on: September 15, 2020, 04:15:28 PM »
There is one listed by AMK ( www.amkproducts.com ), B-11662. It is 1 7/16 inch long, I assume the measurement is made from under the head to the end of the lead point tip. I don't know if that is the same length used on your seat track, but is may be a viable option.
« Reply #6 on: September 15, 2020, 04:55:21 PM »
A lot of great help here.  Thank you guys.
Corey
