Author Topic: Vacuum & PCV fittings  (Read 380 times)
Offline Angela
« on: January 17, 2021, 08:17:24 AM »
Looking for all vacuum and intake manifold fittings for use with 1970 big block. Trying to find good used originals or service parts made in USA. Thanks!
(1) Vacuum advance fitting: D0AE-12A091-A   or C8AE-12A091-A (I think this is also a Motorcraft DY-126)
(2) D0OZ-6A666-A or Motorcraft EV-51 PCV valve
(3) Intake manifold fitting C8LY-9A474-A or D0ZZ-9A474-A
(4) The brass adapter between PCV and carb spacer hose used on 1970
Re: Vacuum & PCV fittings
« Reply #1 on: January 17, 2021, 06:56:03 PM »
Should be able to help out with the PCV valve will check  what I've got and the markings then PM you with what I find.
Don't recognize any of the others, except the PVC adapter/block, by there part numbers
Good luck with the search
