Author Topic: Gas filler pipe?  (Read 1560 times)
Offline KevinK
Gas filler pipe?
« on: January 03, 2022, 02:16:27 AM »
While working on a friends 66 coupe, I noticed the fuel tank inlet pipe seems to be shifted to the left. The gas cap and filler pipe are centered and aligned to trunk latch. It seems odd for it to be shifted. The coupling hose has a wire clamp on the tank side and a worm clamp on the filler pipe side. Is this normal or should I be looking for signs of major damage? I did not see anything with a quick inspection.
Thanks or any input.
MCA #33800, Gold Card 3rd Gen
BAMA Member
Re: Gas filler pipe?
« Reply #1 on: January 03, 2022, 11:27:09 AM »
The non original replacement worm clamp suggests that the hose and or filler neck have been messed with for some reason.
« Reply #2 on: January 03, 2022, 12:36:31 PM »
By how much? And do look for damage, especially frame. There are frame measurements in the service manual.
« Reply #3 on: January 03, 2022, 05:42:38 PM »
Looked at a car not long ago where the whole back half had been rebuilt. The trunk latch support was so far off the bracket looked to be bent at almost 25 degrees towards the passenger side so that the trunk latch would line up with the trunk lid. This meant that the filler neck needed to be angled differently a bit to compensate also
Offline KevinK
« Reply #4 on: January 03, 2022, 10:35:26 PM »
Ok, I just wanted to be sure it should all line up centered. I have never worked on 65/66 cars before.  This car has been banged up a bit here and there. I don't see signs of any thing moving more than an inch or two.
I suspect the issue is at the gas tank.
BAMA Member
« Reply #5 on: January 04, 2022, 01:06:10 AM »
Yes not leeway on a 65-66 and the support bracket is shallow
Hope these will help in some way with your issues. Not easy to find a straight on picture
