Author Topic: C7AZ 9A538-C carb spring -Found  (Read 642 times)
Offline Wills70
« on: May 03, 2023, 05:24:05 PM »
Looking for this spring for my Autolite 4300  4V carburetor - C9ZF -C ,  Ford description -  Spring Accelerator Pump Over-travel
Any suggestions on where to search for this would be appreciated
Thanks Will
« Last Edit: June 01, 2023, 04:16:53 PM by Wills70 »
Offline Wills70
Re: C7AZ 9A538-C carb spring
« Reply #1 on: May 06, 2023, 06:29:07 AM »
Picture of spring in need
« Reply #2 on: May 06, 2023, 01:10:53 PM »
You need a better picture of the spring and measurements of length and diameter IMO. ;)
« Reply #3 on: May 06, 2023, 01:52:08 PM »
The spring has relatively common use. I found over two dozen carburetors using it. Check out this page in the carburetor parts lists - Section 95.17 page 16 - where 10 are listed as an example.
