Author Topic: Ignition switch ground strap bracket (screw type ?)  (Read 2984 times)
Offline Kyle Zammit
« on: August 16, 2023, 05:59:27 PM »
Hi all,
I am looking for information about these two types of screws for the ignition switch bracket.
Here is a picture showing the two types of screws. Not shure if the philps head were used on 67 Mustangs and 67 Shelbys
Thanks Kyle.
Re: Ignition switch ground strap bracket (screw type ?)
« Reply #1 on: August 16, 2023, 07:45:30 PM »
Did you look in this forums' library under topic "Mustang Hardware Spreadsheet 67-68"? Just asking.
« Reply #2 on: August 16, 2023, 10:30:08 PM »
Hi all,
Thanks Kyle.
You asking about San Jose specifically?
« Reply #3 on: August 16, 2023, 11:32:11 PM »
Hi all,
Thanks Kyle.
The hex screw was typical on 67 Shelby's/SJ Mustangs .
Offline Kyle Zammit
« Reply #4 on: August 17, 2023, 01:29:01 AM »
Yes I am looking for San Jose Specifically.
« Reply #5 on: August 17, 2023, 04:22:57 AM »
Here is a close up from an unrestored 67 San Jose Mustang with a VIN just over 7R200xxx
Can't make out the head markings fully looks like it possibly is the one marked CF on the head like the one in your picture. On a GT Mustang the screw also secured the bracket the grill light switch was mounted in also as shown in the picture. Got lucky and had this picture.
« Reply #6 on: August 17, 2023, 11:15:41 AM »
CF is one of a couple typical head markings I have seen used there.
« Reply #7 on: August 17, 2023, 11:18:11 AM »
The bracket is typically unpainted bare steel when I have observed it.
Offline Kyle Zammit
« Reply #8 on: August 17, 2023, 12:25:41 PM »
Thanks for all the information. I Have two brackets they are bought bare steel. The one with CF screw was removed from a 67 Mustang  SJ built Nov 1966 and the other one with Phillips screw was removed from a 67 Shelby SJ built Dec 1966.
« Reply #9 on: August 17, 2023, 02:44:34 PM »
Since the Phillips screw is not called out in the engineering drawings as typical the indication would reasonably be that it is ether a seldom used alternative or a replacement . If seen while judging and I noticed it I would need some kind of reasonable proof that it was original to the given car . That is because of the out of the ordinary usage. That is just me.
Offline Kyle Zammit
« Reply #10 on: August 17, 2023, 05:06:18 PM »
Ok thanks to all for helping me. I will do the CF hex screw. Thanks for everything!
« Reply #11 on: August 18, 2023, 07:38:19 PM »
For those wondering, it's item 11 in this pic (screw 55907-S2).
« Reply #12 on: August 19, 2023, 08:03:35 PM »
Not so fast.
First: 55907-S2 is documented (AMK Guide - pg149) as a 8-18X1/2 HH, Washer, Type AB (looking for the defination of Type AB vs a Type A, it may be threads per inch, or tip) with a 1/4 inch hex drive (I measured it). It is identical in dimensions to 373611-S (they are on the same AMK page next to each other). I have a container of 8-18X1/2 HH screws (over 50) and NONE have a CF head marking - REPEAT - none. Most have Type 30 head marking (see attached). Most of the hardware I have came from salvaged Mustangs that were built in Milpatas, aka the San Jose plant.
Second: The most common CF marked head screw I have seen is 42127-S, a 10-12X1/2 HH, Washer, Type A (see above, same AMK Guide page - get a copy). It has a 5/16 inch drive. Note the difference in screw diameter and drive.
Third: On the assembly line, a worker uses a power driver to install screws. You can cram a size 10 screw into a size 8 hole. I'm not saying that was done, but it could have happened.
Fourth: A picture does not give dimensions plus type (diameter, threads per inch length and tip). Keep that in mind.
« Reply #13 on: August 19, 2023, 11:11:22 PM »
Did get a chance to look at a few unrestored 67 San Jose examples in the last few days and since this subject came up I did look at this details while I was looking over the cars. Each had the same hex headed screw with the CF markings on the head.  As an aside and since Jim brought it up I also have a collection of hardware just about 90% from San Jose built cars and have a fair number of CF marked hex headed screws but I can't report, without going through buckets their exact length or size.
Jim not sure what the page from AMK's publication was for but sure you had a reason. Easy to see that it doesn't represent all of the companies or head markings found originally on our Mustangs and Shelby's   :)
« Reply #14 on: August 20, 2023, 03:42:55 PM »
It's the size that is the question, and the only visible difference available is the drive size of the hex head screw.
..  I also have a collection of hardware just about 90% from San Jose built cars and have a fair number of CF marked hex headed screws but I can't report, without going through buckets their exact length or size.
I went thru a container of around 50 55907-S2 screws and none had a CF (AMK Type 6) head marking. (Wanna play the "Lotto"?)
.. not sure what the page from AMK's publication was for but sure you had a reason.
The majority of screw heads I have for 55907-S were marked with AMK Guide Type 30 - an "O".
Another page is attached from the AMK guide, pg 149 (third edition, my 1st edition is marked up with way too many notes), showing measurements for 55907-S and 373611-S (plus 376386-S which is shown as stainless), plus 42127-S, the most common screw I have found marked with a CF head (also marked with "FC" in the same font, plus "RBW" and a few others). Note: the drive size is omitted in the AMK guide on this page. I measured the drive size as 1/4 inch hex for size 8 screws, and 5/16 inch hex for size 10 screws.
Screw 55907-S is shown in the latest AMK catalog I have (2019 Bulk) on pg 79 with an "A" in two circles head marking.
To Kyle; Measure the screw you currently have installed and report it's measurements.
