Author Topic: 66 fastback outer, rear seat belt holes  (Read 1283 times)
« on: December 20, 2023, 01:46:28 PM »
There are a few topics about the outer (wheelhouse side) seat belts holes and anchors but all the picture links are dead.
Does anyone have a good picture of where these are located on a 66 fastback? I tried using my 67 FB as a template, but the side panel supports welded to the floor are in a different place.
Re: 66 fastback outer, rear seat belt holes
« Reply #1 on: December 20, 2023, 02:16:22 PM »
Jan '66 Metuchen GT FB
« Reply #2 on: December 20, 2023, 02:39:02 PM »
Thanks, Charles!
I need another detail on the dual exhaust holes, but I'll start another thread (with your pic).
« Reply #3 on: December 20, 2023, 04:28:05 PM »
Thanks, Charles!
See attached.
Get a set.
A photo to confirm - 66 K GT Fastback, San Jose, 18K scheduled build. The threaded nut is pressed/stamped/welded in, no separate nut.
« Reply #4 on: December 20, 2023, 04:53:40 PM »
If you mean the Assy Manuals, I have the 64.5, 65 and 66 versions.
But the hand drawn "pics" do not show the location with respect to the metal supports for the side panels.
I took my 67 parts car "plates" and will reuse them on this car.
« Reply #5 on: December 20, 2023, 06:17:29 PM »
What "side panels"?
« Reply #6 on: December 20, 2023, 07:41:19 PM »
The support or bracket on the floor C55ZZ-63310A-084/5-A is called a "Bracket - Qtr trim lower front panel - lower" and holds the "side panels" aka C6ZB-6331486-7 "Panel assembly quarter trim lower front."
Known by some as the rear fiberglass side panels and dozens of other names.
