Author Topic: Engine Tag- 69 H Code Location  (Read 1140 times)
Offline Buzz489
« on: March 03, 2024, 05:25:17 PM »
Where and how is 1969 351W engine tag mounted to the engine? I have a late 69 351W 2V  PS/PB/AC. Any pictures?
« Last Edit: March 03, 2024, 07:14:34 PM by J_Speegle »
Re: Engine Tag- 69 H Code Location
« Reply #1 on: March 03, 2024, 07:17:06 PM »
Attached to the engine with the same bolt that hols the dip stick tube and coil bracket
« Last Edit: March 03, 2024, 07:21:30 PM by J_Speegle »
Offline STAUBY38
« Reply #2 on: March 03, 2024, 10:14:46 PM »
Jeff   Is that also the location for a S code 390 San Jose build Mach engine tag?
C
1969 MACH 1 390 4 SPD
SAN JOSE BUILD 3-28-69
ACAPULCO BLUE BEAUTY
1969 MACH 1 351 AUTO
SAN JOSE BUILD 4-17-69
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #3 on: March 03, 2024, 10:34:22 PM »
No. Different family of engines. Like 428 CJs that year its mounted with the coil bracket on top of the intake manifold drivers side
Offline STAUBY38
« Reply #4 on: March 04, 2024, 06:13:28 PM »
Thanks !
BLACK JADE
2013 BOSS 302
RACE RED
Offline Buzz489
« Reply #5 on: March 05, 2024, 02:53:03 PM »
So besides using the "dip/distributor" bolt, what is the placement of the tag? Is it up/down and was it originally bent at the factory in a particular way?
« Reply #6 on: March 05, 2024, 03:18:54 PM »
I have seen them up or down . Up is probably more readable not bent in a particular way . If you are concerned about this nuance issue you may want to update the finish on bolts in the picture that would be at least as noticable if not more. The hold down bolt typically S7 zinc silver and intake bolts would be painted engine color along with the intake gaskets.Thermostat housing would be painted engine color. There are other things too.
Offline Buzz489
« Reply #7 on: March 05, 2024, 07:59:23 PM »
Thank you all. At this time, I'm test fitting parts on the engine to just see what I need.
