Author Topic: Tac wiring  (Read 4153 times)
Offline BMRBill
Tac wiring
« on: October 29, 2009, 06:51:05 PM »
I'm in process of installing the original tac in the 66 shelby I am restoring. It was not hooked up when I disassembled the car so I am trying to find out the proper routing of the wire that is run to the neg side of the coil. Hope somebody has some info on this.
Re: Tac wiring
« Reply #1 on: October 29, 2009, 10:32:37 PM »
The wire red wire to the coil was on the 65 Shelby tach . The 66 Shelby tach is routed to the factory location in the wiring harness. The repro 66 Shelby tach uses the coil location also.
Re: Tac wiring
« Reply #2 on: October 29, 2009, 11:11:23 PM »
This might help someone
« Last Edit: October 29, 2009, 11:22:18 PM by J_Speegle »
Offline BMRBill
Re: Tac wiring
« Reply #3 on: October 30, 2009, 10:35:09 PM »
Jeff could you fax me that wiring drawing I can't really make all of it out ?
Fax 1217 498 7154
Re: Tac wiring
« Reply #4 on: October 30, 2009, 10:39:12 PM »
No fax on this end. Maybe email me (PM for the address) and I can send it as an attachment.  Have you tried to save the picture I posted to your hard drive then open it with a viewer to increase the size?
Just a thought
