Author Topic: 1967 428PI Ignition Problem  (Read 4422 times)
Offline kkupec02
« on: November 26, 2024, 09:44:42 PM »
New problem with my 428PI. I recently put in a rebuilt date coded distributor with points and condenser replacing my after market electronic ignition. I also put in a rebuilt correct ignition coil. I don't think it has been even 100 miles since it was done. I went to a cars and coffee about 50 miles away 3 weeks ago. The car ran fine on the way there. On the way home, the car started running horribly and backfiring from the front carburetor. It got worse as we nursed it home. At idle in the garage, it is a rhythmic front carburetor pop every 2 seconds or so. I replaced all plugs and plug wires, reconnected the old ignition coil, changed the points and condenser and checked for vacuum leaks all to no avail. Any ideas as I am running out?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: 1967 428PI Ignition Problem
« Reply #1 on: November 26, 2024, 10:03:41 PM »
Sounds somewhat like timing went off; have you checked that?  Could be the condenser is bad.
« Reply #2 on: November 26, 2024, 10:09:53 PM »
Check the float level . They may have gotten stuck. His were stuck way low. I would start with giving the adjusting screw on top of each bowl a good wrap with a screwdriver handle to maybe knock it/them loose. I had a friend with somewhat similar symptoms on his 67 GT500 and that was his problem. You may have to take needle and seats out to inspect and clean before installing and setting the float level.
Offline rockhouse66
« Reply #3 on: November 27, 2024, 08:48:41 AM »
I would put my money on the distributor gear roll pin sheared.  Allowed gear to spin out of place before the remnants of the pin jammed it in a new location.
'66 GT FB
Offline lightwtjet
« Reply #4 on: November 28, 2024, 10:02:43 AM »
rockhouse66 (Jim) is an expert at rebuilding/restoring distributors and air pumps. Good luck.
1968 CJ - Owner and paint original. Dec 67 build in Dearborn. One of 50 135 Cobra Jets. Ford engineering used it for 8 mos. to resolve problems in the 50 early car build. Ford by-passed the normal sign off to get cars to the Winternationals drag race.
Offline kkupec02
« Reply #5 on: November 28, 2024, 12:28:04 PM »
Thanks all. This gives me a couple of new things to check out.
« Reply #6 on: November 28, 2024, 08:01:08 PM »
Yes there are any number of possible culprits that can cause similar symptoms. If it were me I would do the easy checks first like checking the site hole on the carb bowl and check the timing with a timing light.
Offline kkupec02
« Reply #7 on: December 24, 2024, 11:01:53 PM »
I checked all of the "easy" stuff. Then pulled the valve covers and lo and behold, I found a broken push rod. The engine was rebuilt only 900 miles ago by Cobra Automotive. Hopefully they can help me out with some type of warranty or break on the new rebuild.
