Author Topic: Location and position of rear brake line bracket 9" Dual Exhaust Mustang  (Read 409 times)
Offline DaveF
I was wondering if anyone would post a picture of the ?L? bracket that supports the union of the rear brake hard line and the rear brake hose? I would also appreciate a picture of where the vent hose goes into the underside of the floor. If possible, please take the picture far enough away that I can see its relationship with surrounding parts. Thanks!
« Last Edit: May 15, 2025, 06:58:28 PM by J_Speegle »
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Staggered shocks too?
From dual exhaust staggered shock applications from 1970 Dearborn. Likely have more but these were fairly handy.
If this is not what you needed let us know
Floor bracket
Rearend to bracket hose
Brake flex hose retainers
Rearend vent to unibody hole
Offline DaveF
Thank you Bill. Yes, it does have staggered shocks. If I find that I need a couple more pictures, I will reach out. Thanks!
Metuchen plant
Built 9/5/1969
69 is different hose and bracket than a 70 as the main differences is the exhaust pipe routing changes from 69 cross flow to better 70 dual mufflers.
