Author Topic: Autolite/Motorcraft PCVs reference to NOS EV-8 (65-68 289/302)  (Read 1117 times)
Re: Autolite/Motorcraft PCVs reference to NOS EV-8 (65-68 289/302)
« Reply #15 on: June 16, 2025, 12:55:51 PM »
One more point. The second and third files, the ones sorted by Ford part number and Ford service stock number, might be useful if you are searching for PVC valves in a junk yard as other Ford vehicles may have what you need.
I "acquired" a valve from a friend, bead blasted everything, phosphated the spring, retainer and plug, and had the body replated dull zinc. It was "completely restored".
Offline T5owner
« Reply #16 on: June 17, 2025, 03:22:20 AM »
Wow, Great job. Thank you for the huge  effort.
(My MPC CD does not work anymore).
I am sure it will help many and I still think, the need to use a correct opening and flowing PCV is a bit undervalued... with longterm driving at least.
« Reply #17 on: June 17, 2025, 11:29:08 AM »
You can use the one referenced in this Forum's library and, depending on what you use for a computer, download it.
