Author Topic: Cast 67 door hinges  (Read 6765 times)
Offline roddster
Cast 67 door hinges
« on: July 30, 2011, 10:24:49 AM »
I'm pretty sure I already know the answer to this.  I recently purchased a late October 1966 built 67 S code coupe.  The top upper door hinges seem to be the later stamped ones.  Seems this is not correct, the car should have all four cast hinges.  Am I right about this?  If so, I've got some time to find the correct hinges.  The resto on this starts next year. Thanks.
Offline TLea
Re: Cast 67 door hinges
« Reply #1 on: July 30, 2011, 10:39:07 AM »
Rod, I believe that is correct but I'm not 100% as to the changeover date
« Reply #2 on: July 30, 2011, 12:45:24 PM »
Rod, my December 20, 1966 San Jose car originally had all four cast hinges.  I replaced an upper one in 1981 with a stamped version, and have a cast version to put back on soon.  John
« Reply #3 on: July 30, 2011, 06:29:25 PM »
Looking at my collection it appears that the change over was sometime in the 166442-175363 Sorry I don't have Marti reports for all the real build dates. The pictures show 7R189290 and 7R195363 as having cast upper hinges and 7R166442 and 7R175087 as having stamped ones
« Reply #4 on: May 07, 2014, 09:46:07 AM »
I'm trying to sort out this changeover date for San Jose's too, though I may be already OK on my inventory.  My San Jose 11/2/66 build date vin 1274** car looks to have come with the split design on the door hinges. I do not ever remember ever changing anything on the drivers door hinges and the upper was the stamped steel,while the lower was cast. The right side door right now are both cast, but I know I changed the right door and hinges back in '78 because the car was sideswiped when I bought it.  I am happy I was given the 2nd set of doors about 18 years ago that both seem to have the correct split design hinges. I'll look again at those doors in storage and if I find a data tag with a vin, I'll post those numbers too. Going back to the door that has BOTH upper and lowers made from cast, I have no idea what plant the car was built at, but I got the right door, the hinges, the right fender (no headlamp housing) the right side spindle and right lower control arm all from the same car that hadn't yet been painted. These parts were found in a salvage yard in Fontana Ca., so more likely also a SJ build. I know there are date codes on the fender and assume there are date codes on all the other parts too. Since I'll be dismantling it to go on the rotisserie within a few weeks, I'll see what I find out as I go over these items in restoration.  If anybody has interest in my findings, chime in and I'll try and PM you what I find out.
« Last Edit: May 07, 2014, 09:58:52 AM by 67gtasanjose »
Offline Rsanter
« Reply #5 on: May 07, 2014, 01:24:12 PM »
I have some of the original cast door hinges if you need them
Bob
Bob
66 mustang GT conv 289 AT deluxe int - high school car
66 mustang conv 289 -3x2v-4spd deluxe int
68 mustang conv basket case
69 mustang conv 302 AT
66 mustang coupe hotrod/racecar
« Reply #6 on: May 07, 2014, 06:10:01 PM »
Subject is a few years old - guess we can do another survey of examples to see if something new pops up ;)
« Reply #7 on: May 07, 2014, 07:26:58 PM »
Kinda what I was thinking. Mostly thinking there is some discrepencies in this post. I absolutley know, without a doubt, that my right door was changed in '78 and I installed a door with both cast hinges. I REMEMBER clearly that they were different at the time, but could care less as a teenager. I am OK with going either way myself, as long as they are the same but would really like to get it right for sure while I'm at it.
I read this, and this quote matches perfectly to all of what I remember about my car which is a Nov. 2nd, 66 (really close)
« Last Edit: May 07, 2014, 07:31:10 PM by 67gtasanjose »
« Reply #8 on: May 07, 2014, 07:31:59 PM »
Ok for input into the survey-
Include VIN or assembly plant and build date for your findings.
From there we'll see what sort of pattern shows up
Going to take time for me to go through the hundreds I've got - hopefully many will have shots of the hinge areas  :o
« Reply #9 on: May 07, 2014, 08:18:14 PM »
I checked the pair of doors I've had kicking around for last 18 years and I do have a data plate with dates etc.
7R01S1516** vin, so it's a SJ 390 Coupe
13M date, scheduled build date December 13th, 66, other features are DSO 71, C-6 trans, 3:00 open differential
As I said earlier, these doors also have the stamped uppers, yet cast lowers, just like what is still on the (never changed) drivers door of my sched. build,Nov. 1, actual built Nov.2nd. Looks like a concistancy for the SJ coupes at least from late October thru mid December by my findings and an earlier post by roddster. 67gta289 seems to complicate these findings though.  btw, These doors in storage have never been repainted and are the original lime gold. Hinges show no signs of having been removed from the doors before.
« Last Edit: May 07, 2014, 08:38:53 PM by 67gtasanjose »
Offline Paperback Writer
« Reply #10 on: May 07, 2014, 08:19:47 PM »
VIN = 7R03S110###
Plant = San Jose
Actual Build Date = 9/22/1966
Door Hinge Type = Cast (both upper and lower)
1967 390 GTA Convertible
7R03S110###
« Reply #11 on: May 07, 2014, 08:32:24 PM »
It looks to me like these hinges must fit other older model Fords too, possibly 66's?  and they ran the inventory till they depleted the stock on hand, running out of the uppers first, switching the lower from cast at a later, yet to be determined date.
« Last Edit: May 07, 2014, 08:34:21 PM by 67gtasanjose »
« Reply #12 on: June 02, 2014, 11:03:42 AM »
UPDATE:  I pulled the fenders & doors this morning, and found IMHO proof that indeed my drivers side UPPER ONLY, is supposed to be the stamped steel, while the lower is cast. Other owners seem to provide evidence that other original cars built in SJ AFTER mine, have hinges that are both the cast type. (uppers and lowers)
The "smoking gun" for my car having the upper as original, that is, not a replacement hinge, is the dumb-dumb sealant still stuck to the top of the hinge. I can scratch through the paint on the dumb-dumb sealant to check it further, but unless this sealant was maticulously done while the car was like new, say at a dealership to stop up a cowl leak (Barstow California Desert area...not likely) AND while they were in there changed BOTH of the upper hinges AND repainted them to match perfectly AND the other set of doors with the same type of hinges I have (steel upper, cast lower) dated Mid December had BOTH upper hinges replaced too AND was maticulously repainted...Yeah, a little far fetched!
It looks to me that the assembly line workers must have begun using the stamped type for a while and possibly went back to the cast type for a stretch of time. As for my car, I am going back to how it was built, possibly against what judges might wish to see on my hinges, given it's build date. I already have another set to replace the "known to be replaced incorrectly", right side upper.
« Last Edit: June 02, 2014, 12:08:09 PM by 67gtasanjose »
« Reply #13 on: June 02, 2014, 12:17:13 PM »
Here is the original quote, which started this thread "A long time ago in a galaxy far, far away...."
IMHO, it looks to me like you may have been "Duked" into believing they were the wrong hinges when indeed, likely were the right ones.
« Reply #14 on: June 02, 2014, 12:51:40 PM »
I have a different question after I thought about this for a while, a possible different scenario that might explain things. Please, if anybody knows differently, offer your knowledge.
Were the doors assembled in a different sub-assembly area, already painted and stock-piled or racked and made available to the main assembly line as needed?
If so, it would be concievable that certain "X" quantities of any particular color would be built up in surplus to expedite the final assembly. In that situation, there would eventually be, for lack of better understanding, some of the early style in the back of the rack and one day finally make it to the main line.
This is just an idea. Maybe many of you already know this IS how, or IS NOT how they did things, but I don't know most assembly line practices. It seems here at this site, many of us are still learning these things.
Richard.
