Author Topic: Spray can - Corporate Blue Engine Color Attempts, Results and Attempts  (Read 47427 times)
Offline RocketScientist
Re: Eastwood engine paint dark blue not matching
« Reply #15 on: June 10, 2013, 10:12:50 PM »
Jeff, in your experience, was the color difference there when the engines were first built or could it be due to big blocks generating more heat and therefore degrading the paint more, to produce the darker blue.
« Reply #16 on: June 11, 2013, 12:38:58 AM »
More likely IMO because they were built at a different engine plant where the paint may be a slightly different formula.
« Reply #17 on: June 11, 2013, 12:54:39 AM »
Might be that Eastwoods colors (never used them my self) are just "off"
I don't use Eastwood's "designated to a manufacture paints" (like engine colors) or their 'under hood black (too glossy - make the "Bow Tie" guys happy though), but I do use their reflective aluminum (for inside tail light buckets), carb touch up and high temp exhaust paints, mostly on non-concourse cars.
Offline 67BB390
« Reply #18 on: June 17, 2013, 11:26:46 AM »
New batch same as before :( Will send them a painted piece to show them the right color.
Offline Drive Fast
Re: Spray can - Corporate Blue Engine Color Attempts, Results and Attempts
« Reply #19 on: February 15, 2017, 11:07:26 PM »
share your advice. What would you do?
Just before motor and transmission install, I checked one more time on engine color. Looks like my engine builder picked a medium blue rather than dark ford blue. Which is the right color? Would you take the engine apart to paint it dark blue or paint the accessories to match the medium blue?
It's a numbers matching car that could be a good candidate for concourse showing in the future.
« Reply #20 on: February 16, 2017, 12:06:21 AM »
I can't speak for Chuck but if it were my engine and strictly going by the choices presented and the way the paint looks in my laptop monitor, the can in the middle looks best of the three. The one on the right is too light and the one on the left doesn't look right ether
« Reply #21 on: February 16, 2017, 04:28:09 PM »
Since your going with the rattle can - why guess?  Instead just purchase one of the products already identified in prior threads and go with those suggestions
Looks like you went to the Dupli-Color products already
Offline Brant
« Reply #22 on: February 16, 2017, 05:48:44 PM »
We handle the DupliColor brand of spray paint in these cans. I gathered up quite a few original valve covers and air cleaners in order to choose the closest matching color. First, I will say that the colors slightly varied over production times.
Second, and most importantly, those caps on the cans are not an exact match to what is inside.
Anyway, in my opinion, the DE1606 is the closest to what starting being used in 1966.
« Reply #23 on: February 16, 2017, 08:37:56 PM »
+1 on the 1606
Offline Frostbiten
« Reply #24 on: February 16, 2017, 11:35:06 PM »
1606 +2
1968 CJ FB Tahoe Turquoise
Offline Hawkeye
« Reply #25 on: February 17, 2017, 01:12:39 PM »
Chuck would stare at what has already been painted until the color changed to the color he is imagining in his head.
Offline Drive Fast
« Reply #26 on: March 28, 2017, 12:30:16 AM »
Thanks 'y'all. Chuck stared at it but nothing happened, so I scrubbed it down with lacquer thinner, wax/grease remover and repainted it. It looks great! Now to put on the accessories and install it...
Offline markb0729
  • South Jersey
« Reply #27 on: March 28, 2017, 10:30:49 AM »
Next time you paint an engine get a set of old valve covers or completely cover the part of the head under the valve covers.  I've seen people paint that part of the head only to have the paint eventually chip off and partially clog the pick-up screen in the oil pan and clog oil passages.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline Building 3
« Reply #28 on: March 28, 2017, 10:49:15 AM »
Did you repaint with the 1606? From my monitor it looks much better.
Offline Drive Fast
Yup. 1606 paint is much darker than were it started.
Had my knee replaced about a month ago, chomping at the bit to drop the motor in. It's sitting on the floor taunting me every time I go out...lol.
