Author Topic: help 69 drive shaft marking  (Read 6183 times)
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« on: November 20, 2009, 01:05:19 PM »
OK the car build sheet call for a drive shaft LBLARD CODE C it a 69 NJ built car in April 4spd 351 4v .no ac,ps and no power brake
so light blue , lavender and red marking? what is the C mean? , would anyone have a pic of this color marked shaft.it was gone from the car so i don't have anything to get the correct color shade from for the marking or what style shaft is correct
Re: help 69 drive shaft marking
« Reply #1 on: November 20, 2009, 05:17:19 PM »
Not sure of the additional letters that are included in each of these may be the bin, shelf or level number.
Sorry don't have an original example of such a driveline but here are some examples of the three colors. Be warned that due to the changes digital camera make, monitor settings and such what your seeing will likely not be exactly what would be seen in person. Have seen examples of the light blue and lavender which were paler than what appears on my screen. Hope this helps
Offline DEWilson
« Reply #2 on: November 20, 2009, 11:56:18 PM »
 got a sample of the Light blue of a differant shaft.  does it matter if the color order run front to back  BL LA RD OR back to front
Does anyone have more pic of the la color or the red
thanks for the help
« Last Edit: November 21, 2009, 10:18:12 AM by DEWilson »
« Reply #3 on: November 21, 2009, 12:09:24 AM »
Yes colors on the build sheet should run (they are listed) front to rear.
Does anyone have pic of the la color or the red
Yes all three are shown above
Offline DEWilson
« Reply #4 on: November 22, 2009, 12:09:02 PM »
[/quote]
yes I did see them and one is a pic I posted. I was asking and looking if anyone may also have some pics that they would like to add just to use as a comparison of the colors, to try to make up a good match as close as possible.
« Reply #5 on: November 22, 2009, 02:20:25 PM »
Sorry misunderstood your post. Thought you might not be able to view for some reason
Offline DEWilson
« Reply #6 on: November 23, 2009, 12:01:18 PM »
no sorry needed Jeff  and thank you very much for your help and wish every one a happy Thanksgiven!
Offline BuckeyeDemon
    • Photobucket Pictures
« Reply #7 on: December 01, 2009, 12:09:47 AM »
not sure if this is what you are looking for.  i also can't promise that it's the original driveshaft.  mine was a 69, Dearborn, 351W 4V, 3-sp.  It has a 4-sp in it now, so not sure if that would have caused someone to swap it.  maybe jeff can confirm.
VIN: 9F02M178303
Build Date: March 31, 1969
1969 Mach 1, Candyapple Red, 351W 4V
Offline DEWilson
« Reply #8 on: December 03, 2009, 12:00:43 PM »
  thank for the pc would-ed think that they had to change out the shaft from 3sp and 4sp use the same length shaft ,is that a one piece shaft or a two piece was the first strip light blue
« Reply #9 on: December 03, 2009, 02:27:59 PM »
BuckeyeDemon  thanks for the picture
Looks like (left to right red, lavender, white - last one out of the picture)   Guess (you would be the best one to know since digital settings can change everything) that the white could be light blue if you could confirm. If so that would match the buildsheet for the 3 speed. Could not find a copy of a 4 speed one in my files
Is it from this car??
VIN: 9F02M178303   - Build Date: July 31, 1969
1969 Mach 1   -    351W 4V
« Reply #10 on: December 03, 2009, 09:00:21 PM »
it's a very light blue and it is from the car you have listed.  with the exception of my mistake. build date should be 3/31/69 per the invoice.
i like how the paint appeared to have nice runs...
there were a few more marks on it.
VIN: 9F02M178303
