Author Topic: '65 Battery clamp  (Read 4026 times)
Offline C5ZZKGT
  • Gold Level Subscriber
'65 Battery clamp
« on: September 24, 2011, 06:52:50 AM »
My July 27th scheduled build date (1965) (Dearborn) K code has/uses a group 24 battery (the reproduction one from Antique Battery in Ohio) and the "short" hold down clamp.
My question is should the hold down clamp have the half-circle cut-out tab like the longer clamp that is made for use with the group 22 batteries?
Offline C5ZZKGT
Re: '65 Battery clamp
« Reply #1 on: September 24, 2011, 09:49:28 AM »
-It seems (to me) that the one for the group 22 battery-(the long one) is the one that has the cut-out, I have looked at pictures of NOS ones for the group 24 battery and there doesn't appear to be enough room for a cut-out....
Online CharlesTurner
« Reply #2 on: September 24, 2011, 10:52:05 AM »
Ford serviced the short ones with and without the tab.  Your July '65 Dearborn car most likely had one with the tab.
Would be very careful about using service replacement parts as a reference for assembly line correctness.
Offline mgmradio
« Reply #3 on: September 24, 2011, 10:57:19 AM »
Both clamps have the cut out.It fits in the notch along the base of the battery.There are atleast 2 versions of the Group 24 clamp.1 with the half moon and 1 with a tab.
  Mike
Formerly the MCA ANHJ 64.5-66!
Offline C5ZZKGT
« Reply #4 on: September 24, 2011, 11:22:01 AM »
OK, Thanks guys! Obviously there is not a correct repro on the market yet??
« Reply #5 on: September 24, 2011, 11:34:28 AM »
Not at the moment, but a competent machine shop could probably modify one without the tab to be correct.
Offline C5ZZKGT
« Reply #6 on: September 24, 2011, 03:39:57 PM »
Thanks Charles! I never considered that. Would you or anyone else have a picture of what a correct one looks like? Like I said I've only seen the longer ones for the 22F batteries so far with the tab. (Thanks!)
« Last Edit: September 24, 2011, 03:41:53 PM by C5ZZKGT »
Offline Chris
« Reply #7 on: September 28, 2011, 10:01:27 PM »
I just purchased one, NOS factory original w/tab (not a service part), and I should have it in 2-3 days. I'll post a picture when it comes in.
64 1/2 Poppy Red Convertible, 260V8 auto, 19 June 64
« Reply #8 on: September 29, 2011, 02:09:15 AM »
I just purchased one, NOS factory original w/tab (not a service part), .................
If its a NOS part then its a service part - just likely an early - correct or more correct one ;)
Glad to see you found one
Offline C5ZZKGT
« Reply #9 on: October 02, 2011, 01:02:44 PM »
Guys, Het thanks for the imput on this and the picture offer Chris.
-Something so small.....seems like it would be easy enough for whomever is reproducing the short ones with the tab to just do the short ones the same way and be done with it.
-I'll bet an outfit like Scott Drake or Daniel Carpenter could do it with no problem.
Offline C5ZZKGT
Offline Chris
« Reply #11 on: October 08, 2011, 03:28:00 PM »
Here are some pictures of the correct 65 battery clamp for the Group 24 battery. I just received this in the mail yesterday, still has the FoMoCo part tag attached.
Offline C5ZZKGT
« Reply #12 on: October 10, 2011, 02:18:50 PM »
Chris, Hey Thanks for sharing the pictures!
Guys, wonder what is used to make this "tab" at a machine shop.....not sure if I have a competent one around here....
« Reply #13 on: October 10, 2011, 03:52:47 PM »
I always thought the semi-circle could be cut with a laser and then the tab bent over.  Just never pursued it, usually able to find and original or NOS with tab when needed.
