Author Topic: 14" tire clearance at frame rail  (Read 3982 times)
Offline C5ZZ
« on: October 15, 2011, 11:17:27 PM »
Was reading in "Mustang Genesis" that Ford found
a problem with the tire scraping the frame rail on a
hard turn and used a fix of torching out a small area
of the frame rail. They continued this on for 64-66.
Was this just done on cars with 14" tires?
How about ones with 13" tires were they cut also?
MCA # 00945
65 Fastback, 6 cyl, AT, AC, PS, PB
Rangoon Red/Red Interior
Re: 14" tire clearance at frame rail
« Reply #1 on: October 16, 2011, 12:54:15 AM »
Very early in production, the frame rails were modified so they were notched, so they wouldn't require any modification, like using  torch on the early cars.  Not sure when the change was made or if the torched frame rail cuts were simply a pre-production modification.
Offline C5ZZ
« Reply #2 on: October 16, 2011, 05:50:28 PM »
From the way he talked in the book they continued to torch
the notch on the line into the 66 model year, it was cheaper
for them to torch the notch rather than redesign the frame rail.
My car has the torched spot and it's a Dearborn 8/64 date.
MCA # 00945
Offline Pete Bush
« Reply #3 on: October 17, 2011, 07:14:28 AM »
The way I read Fria's statement, only the frame rails on cars with 14" tires were modified - to avoid rubbing in a sharp left turn. 13" tires wouldn't have been a problem because that's what was used on the Falcon without issues..
Fria's book details the design and building of the very early Mustangs. When he talks about the practice of "using a torch to crudely cut away a portion of the outer lower lip of the rail", I believe he is talking about the 64-1/2 model year. Then when he is talking about the practice being "used into the next model year", I believe he is talking about '65.
'66 6-cylinder Sprint Convertible
Metuchen - Scheduled May 10th; Built June 21st
« Reply #4 on: October 17, 2011, 11:24:55 AM »
Got a Jan '65 Dearborn and a March '65 San Jose car in the garage, both have formed notches with spot welds on the edges.  No sign of torch cut.
« Reply #5 on: October 17, 2011, 12:09:02 PM »
I've wondered about that. My 66 K (Oct 65 San Jose built) has a jagged cut edge about four inches long on the left side outer lip about where the lowest bolt for the steering box is located. I couldn't see any cut on the right side.
Offline Pete Bush
« Reply #6 on: October 17, 2011, 02:10:50 PM »
Yes, according to Fria, it was only the left side.
When did Ford make the transition to using only 14" tires on Mustangs?
Offline svo2scj
« Reply #7 on: October 17, 2011, 04:56:36 PM »
Wish Bob had said "Passenger" or Driver - as I'm looking at right side/Passenger here!
Mark
« Reply #8 on: October 17, 2011, 07:30:55 PM »
Just did a look-see on my 66 Hardtop (Oct 65 San Jose build) and a 66 Shelby (Feb 66 build) and both sides frame rails are notched. The Shelby's RH frame rail seems to be saw cut or even notched as part of the fabrication process, it's very smooth.
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #9 on: October 17, 2011, 07:36:01 PM »
Sept 28 64 Dearborn, tourch cut.
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Online jtfx6552
« Reply #10 on: October 23, 2011, 09:22:14 PM »
My 29K 64 6 cyl fastback which came with 13" wheels had what appears to be torch cuts on both sides.
« Reply #11 on: October 24, 2011, 06:12:56 PM »
You'll notice that if those are torch cuts they did not improve clearance at all  (notice the depth is the same or less than the prepressed design of the two sections at the leading and following edges -
IMHO what we are seeing are more likely some form of weld rather than cutting based on the evidence.  Maybe earlier in the production (first month or so) they needed to do something to over come a problem short term but looking at some of the examples posted it did not gain any clearance -
Will have to ask a couple of workers if they recall anything related to it
Online jtfx6552
« Reply #12 on: October 24, 2011, 09:38:15 PM »
I'm not following you there? Looks like they'd increase clearance to me?
« Reply #13 on: October 24, 2011, 10:08:34 PM »
Since the forward and rear diagnial edges are left un touched and as formed -
A picture directed straight up would likely illustrate the differences better
