Author Topic: 66 shelby leaf springs  (Read 17548 times)
Re: 66 shelby leaf springs
« Reply #15 on: November 18, 2011, 03:01:36 AM »
You'll be looking for the C4ZA-S springs
Looking at other examples (with tight spring to sheet metal date) I would look for ones stamped at least a month prior to the sheet metal dates. Maybe something between 250-290 but anything close should work
Remember the dating format is 234 E 5 - with
234 being the day of year - Julian year
E being the supplier
5 being the year
A usable site for figuring out the numbering system http://amsu.cira.colostate.edu/julian.html
Dan, since the rear leafs are rare  I would not miss a opportunity to acquire ANY C4ZA-S rear leafs. They are in such demand you can always sell or trade them if another more appropriate dated one comes along. Bob
Offline s2ms
    • 6S1757 Info
« Reply #16 on: November 18, 2011, 01:07:09 PM »
Thanks Dave for another data point for my spread sheet.
Don't get allot of spring dates since they are so often swapped out over the years as they weakened.
Dates are always interesting since some parts were produced in an on going basis while others were produced in batches, likely due to demand or the machines that produced them. Our cars are over 10,000 numbers apart (Ford VIN) while the spring dates are weeks apart
You're quite welcome Jeff. The rear springs are one of the earlier dates on 6S1757. You may remember we've discussed them previously on the HiPo and SAAC forums. They are a little weird in that one spring has paint daubs and the other stripes. Plus on the striped spring you can see where a worker put the stripe colors in the wrong order and then painted over them in the correct order. You may already have this pic but just in case here it is again...
Dave
« Last Edit: November 18, 2011, 01:51:27 PM by s2ms »
« Reply #17 on: November 18, 2011, 09:17:46 PM »
Yes already have a copy - and for others DON"T COPY THIS EXAMPLE !!!!  They are not what we typically see.
I've only seen a handful of cars where they mixed stripped and dotted rear spring markings. Dots are not that common on a later 66 car from my experiences
Offline s2ms
    • 6S1757 Info
« Reply #18 on: November 18, 2011, 11:47:59 PM »
Sorry, didn't mean to imply this was a normal thing, definitely not, but obviously it did happen.
Jeff, Just out of curiosity, what are the dates on the other springs you've seen with mixed stripe and daub markings? Just wondering if there was a transition period where it was more.... "likely to occur"....
Dave
« Reply #19 on: November 19, 2011, 09:59:21 PM »
Don't think you did but we all know how the lurkers see something and run with it ;) so I thought a warning was appropriate
No pattern a couple in 65 and a couple in 66 so either a worker grabbed a rattle can or daubed the paint when he should not have,  a handful of of dotted springs got left back or the transition was really irregular I can't put any cars together by VIN enough to get a pattern
This the one of each (marking style) is not normal but would not deduct for it if I saw it at a show. Would likely ask if the owner found it or made it that way.  Know one restorer that does just about every one of his 65-66 Shelby's that way :( based on one example/car in a magazine
Offline Texas Swede
« Reply #20 on: November 20, 2011, 08:20:11 PM »
While we are talking about rear springs for 66 Shelbys, these are the originals
on 6S923 in Sweden. The clamps look quite different from the ones I have
seen on most rear springs. The original yellow and green stripes have been recreated exactly
as they were originally. One picture on car and one before restoration.
These are marked
C4ZA
5556  S
345 E5
Texas Swede
« Reply #21 on: November 20, 2011, 08:48:17 PM »
on 6S923 in Sweden. ..............
Thanks Bo - yes sometimes all we can see fo the markings is a spot with less rust/texture
Thanks for the pictures
These are marked
C4ZA
5556  S
345 E5
Funny in that I have ones originally off of 6S1203
One made 343 (Dec 9th) and one made 345 (like your example  - Dec 11th)  and the guys skipped the green stripe :(
Offline s2ms
    • 6S1757 Info
« Reply #22 on: November 20, 2011, 10:06:19 PM »
seen on most rear springs....
Bo,
Those clamps are the same ones used on the Maier Racing springs I currently have on 6S1757. Plus, from your pic it looks like the rears on 6S923 have five leaves, is it possible these are a modified set with a correctly dated original bottom leaf?
Dave
« Reply #23 on: November 20, 2011, 10:32:44 PM »
Bo,
Dave
Good catch Dave - I was busy looking at the other  picture
Offline Texas Swede
« Reply #24 on: November 21, 2011, 01:03:56 AM »
Thanks Dave,
Have to ask Roland tomorrow if his springs have 5 leafs. The car was raced in Belgium
as can be seen by the perculiar panhard rod and the car has the holes through the floor for attaching
shoulder harnesses. Claude Dubois have been asked if he himself raced this car as his
name was found on a Belgian certificate for 6S923. Sofar no answer from Claude.
It was the German guy Wolfgang Kohrn who asked Claude.
/Texas Swede
Offline cobraboy
« Reply #25 on: November 21, 2011, 03:17:51 PM »
Here is a pic of one of my springs. Both have the same date. I know its not a SJ car, but may help in the tie up between manufacture date and build date of a car with these springs. The paint is un restored.
13th April 1965 Dearborn K GT on the other side of the pond.
« Reply #26 on: November 21, 2011, 03:56:39 PM »
Thanks - is that 65th (March 6th) or 85th (March 26th - don't think 65 was a leap year) day of the year (sorry hard for me to make it out?  And this is from your car with a projected April build date?
Just confirming
« Last Edit: November 22, 2011, 01:44:44 PM by J_Speegle »
Offline Texas Swede
« Reply #27 on: November 21, 2011, 05:16:47 PM »
Dave,
You have real eagle eyes as Roland's car indeed has 5 leaf springs. Probably added by Claude Dubois in
Belgium who most likely got them from Maier Racing and added the bottom leaf with the date codes etc.
This explains the special clamps as well. Also I was wrong about the dates, one is 345 E5 and the other
353 E5.
/Texas Swede
« Reply #28 on: November 21, 2011, 07:55:18 PM »
.............Also I was wrong about the dates, one is 345 E5 and the other
353 E5.
Interesting that in the pile of springs two cars (maybe more) got the exact same matching dates.  What are the odds?
Offline YELLOWBOSS2
« Reply #29 on: November 21, 2011, 09:32:01 PM »
Both of my springs are dated 137E5 on my 65.
Dave
