Author Topic: Late '68 Dearborn undercarriage primer colors  (Read 4109 times)
« on: July 23, 2012, 11:37:26 PM »
I'm restoring a 68.5 cobra jet fastback for a friend, May '68 Dearborn car.  Unfortunately, was not able to clean and look for original primer colors before it was stripped.  Getting to the stage soon where the body shop will be needing to know what colors to go with underneath.  So, hoping to get some help here.  Doesn't have to be a CJ car, although would be a plus.  Any April-June '68 Dearborn car would be a good reference.
Thanks for any help.
« Last Edit: June 30, 2016, 06:34:30 PM by J_Speegle »
Re: Late '68 Dearborn undercarriage primer colors
« Reply #1 on: July 24, 2012, 12:34:12 AM »
During that period (April to June) Of course I only have projected build dates at this time and limited amount of samples. So far March-April Red oxide and June with a dark gray batch
Hopefull others will have some original cars to fill in the gaps
Offline Laurie S.
  • Trouble
    • My 1968 Mustangs
« Reply #2 on: July 24, 2012, 12:58:14 AM »
My June 2nd built coupe has the dark gray underside with a bit of sparkle.  The paint for style steeled wheels is an exact match.
Murphy, 1968 Coupe - Concours, Original Owner
Trouble, 1968 Fastback - Modified
MCA Gold Card Judge, 67-68 Concours
MCA Gold Card Judge, Modified - All Years
« Reply #3 on: July 24, 2012, 08:17:22 AM »
Thanks.  Were you able to determine if there was a different shade of primer under the front engine bay area?  Guess you're referring to the 66/67 charcoal gray wheel paint?
Offline Laurie S.
  • Trouble
    • My 1968 Mustangs
« Reply #4 on: July 24, 2012, 10:30:32 AM »
No, it was a pretty consistent color throughout.  Yes, that would be the paint.  I discovered the match accidentally when I was trying to touch up an area near the rear and grabbed the wrong can.  You can't tell the difference between the primer and the spray touchup.
« Reply #5 on: July 24, 2012, 11:54:18 AM »
If the gray was like the gray used in the 69 Dearborn cars it varied (sometimes dramatically) from one batch to the next . Sometimes with metalic sometimes without. Sometimes light sometimes dark  but always a gray like shade. interestingly the begining of production in 69 saw some red oxide shades before changing to the slop gray paint in the Dec time frame at Dearborn. I havn't studied 68 Dearborn cars but it reads like there was a change over pattern in 68 from red oxide shade to gray also. Maybe a build up of excess waste paint which prompted use? or ? Just some more observations for the decussion.
Offline 68 S Code
« Reply #6 on: August 06, 2012, 05:39:25 PM »
The attached is a pic of a june 24th Dearborn built CJ. This car has been owned by the same guy since the spring of 1969 and he reassured me the undercarriage was never touched. I've compared this to Metuchen slop gray and it looks to be black in my opinoin. Kind of a satin black. I feel the flash on the camera is lightening it up to look less true black. It was also pretty dirty and I just tried wiping it down quickly with a shop rag before snapping the pic.
« Last Edit: August 06, 2012, 05:42:37 PM by 68 S Code »
« Reply #7 on: August 06, 2012, 07:43:10 PM »
The attached is a pic of a june 24th Dearborn built CJ. ........................
Thanks - from the samples I have sometimes you have to clean them well (even wax a small area) and take a strong light to see the differences in the very dark products. Again thanks for posting
Offline 1Hotboss
« Reply #8 on: August 08, 2012, 12:57:57 PM »
My 68 built Dearborn car has a june build date, so I am going to say that the undercarriage should be slop grey...it currently is red oxide...I may want to change it to slop grey if I decide to go more to original with the car.....if so can anyone please tell me which paint code has anyone used to obtain a close match or consistent match....
« Reply #9 on: August 08, 2012, 03:17:29 PM »
Think that there won't be a specific paint code as there is variance.  Maybe starting with something like Laurie found... 66-67 styled steel wheel charcoal gray and then tinting it dark or light from there.  Maybe doing without metallic also.
« Reply #10 on: August 08, 2012, 11:05:04 PM »
I've used a late model Volkswagen (2000+) dark gray and simply added a little blue or green to tint it a bit. Came out fairly dark- with a little metal flake and in the last application very slightly bluish. Pretty close to a number of original Dearborn samples I have
