Author Topic: Mustang  (Read 1162 times)
meltdwn65GT
  • Guest
Mustang
« on: November 25, 2012, 05:54:13 PM »
« Last Edit: July 21, 2013, 08:55:37 PM by 5RFastback »
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Suggestions on how to remove Frozen Jets in a Autolite 4100
« Reply #1 on: November 25, 2012, 07:22:49 PM »
Take the body to the airport and have the maintenance guys run it for a day or 2 in the ultrasonic machine.
66 Metuch Conv
Nightmist, Std Blu Int
Offline mgmradio
« Reply #2 on: November 25, 2012, 10:15:59 PM »
Try putting it in the freezer for a few hours.
« Reply #3 on: November 27, 2012, 08:16:23 PM »
You might try some ' Berryman '  it was often used for such things back in the day.  It helps to dissolve lacquer build up.  If replacing the ' power valve '  let me suggest you get the Holley model.  I recently did some work on my Autolite C5ZF-C and had a bad experience with the rebuild kits version and the the NAPA version as well.  The rebuild kits call it the economizer valve.  Brian
