Author Topic: Trunk fuel sending wire, attachment  (Read 2562 times)
priceless
  • Guest
« on: January 17, 2013, 12:10:38 PM »
I need a photo of the trunk fuel sending wire where it attaches to the L.S. trunk seam OR, a good description of its location. I was in Pensecola FL last March and I had a point deducted for not having a "zip tie" attaching the wire to the left trunk seam where the trunk seam protector is located.
What color is the zip tie(white,black?) and the exact location. Any help would be appreciated.
Feb. 24,'69 build date,Metuchen,NJ, '69 Mach1.
Re: Trunk fuel sending wire, attachment
« Reply #1 on: January 20, 2013, 10:56:56 PM »
Opaque ("white") nylon zip tie (about 6 1/2" long)  Normally inserted from the passenger side of the hole, around capturing the wires than through the lock . The end aims towards the passenger side and is untrimmed
What I've always found
« Reply #2 on: January 21, 2013, 03:49:10 AM »
Pan Duit was the MFG. AMK sells them . The electrical supply looks close for most purposes.
priceless
  • Guest
« Reply #3 on: January 21, 2013, 08:43:01 AM »
So, the "zip tie" hold both the eletrical wires and the fuel sending wire?  And also, after installation, it looks like,by viewing the photos,the zip tie isn't clipped, its left long? Thanks for any responses.
« Reply #4 on: January 21, 2013, 02:45:05 PM »
Yes
Offline Brian Conway
« Reply #5 on: January 21, 2013, 05:49:34 PM »
Couple more shots of the same area.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline app01
« Reply #6 on: January 21, 2013, 06:04:30 PM »
Also dead nuts has them and there is no minimum order there.
http://www.deadnutson.com/catalog/item/4065497/4972957.htm
Also click on the link and there is another unrestored example picture.
http://www.deadnutson.com/albums/album_image/4236615/1472519.htm
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Offline drummingrocks
« Reply #7 on: January 21, 2013, 06:18:16 PM »
PM sent.
priceless
  • Guest
« Reply #8 on: January 21, 2013, 07:50:45 PM »
Thanks to all you guys for the replies and pics. Helps out Tremendously!!!
Brett, I sent you a PM back and Thanks very much in advance.
