Author Topic: NOS Hipo Crank Washer  (Read 6175 times)
Re: NOS Hipo Crank Washer
« Reply #15 on: August 26, 2014, 08:24:25 PM »
Ford put a Bulletin out on the size,thickness and weight of Hipo balancer washer.The balancer,bolt,washer and cookie cutter all played part of balance along with flywheel and Hipo rods.If your just putting a motor together without balancing it good luck as we don't do my motors that way and never have.There is a difference on thickness and weight of washer from standard washer.That might be good discussion for someone else to start a thread away from the classifieds!
It was my understanding that the washer did not have to do with balance but was a safety factor to hold the balancer secure at high RPM . A respected SO CAL engine builder Ford guy Randy Gillis told me "Ford engineers felt that the higher rpm potential "could" allow the thinner washer to deflect and lose clamp load on the bolt and eventually fail."
Offline wunderwerks
« Reply #16 on: September 19, 2014, 06:04:15 PM »
My August 69 Ford Parts Book update lists this washer for the 289 spec. as part # C3OZ 6378-A.  It shows the dimensions right in the book as 1 3/4" OD, -21/32" ID, - 1/8" thick.
For all other applications the standard washer is part # B8A 6378-A.  These dimensions are 1.76" OD, -.77" ID, .212" Thick.  This is correct--The standard washer is thicker.
This topic has been bothering me so I crawled under my K-Code and removed the bolt to double check the washer.  It measured exactly with the parts book dimensions.  Now I'll go back and torque the bolt and washer back in.   Hope this helps out my fellow Mustanger.
64.5 Cpe. Poppy Red 5F07D 23G
64.5 Conv. Bright Cherry Sparkle 5F08F 16F
65 2 + 2 Caspian Blue 5F09K  23K
Offline PraireBronze
« Reply #17 on: September 22, 2014, 08:18:15 PM »
C3OZ-6378-A is .32" thick versus standard size of .21" according to Bob Mannel's book, page I-4. A side by side picture comparison is on page 3-14 caption (F).
And there is no way it could have an effect on balance.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
Offline lscman
« Reply #18 on: September 29, 2014, 07:19:11 AM »
Go balance a motor and tell me if the difference in size which effects the weigh makes no difference in the bob weight...ya right!
Offline GT500KR
  • Charlie Ping
« Reply #19 on: September 30, 2014, 12:35:34 PM »
To say that a tiny, or any difference for that matter in crank bolt washer weight would change the balance is pure nonsense. Uniform thickness, and diameter. Spinning around itself. Think about all the different pulleys that were used without adverse effects over the years. Single groove, double, even triple. They would make over 1000 times more difference than a small washer.
sbftech.com/index.php?action=dlattach;topic=19097.0;attach=23211
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #20 on: September 30, 2014, 10:56:16 PM »
Guys we've moved away from the subject of the thread - or at least we're quickly approaching that edge    ::)
« Last Edit: September 30, 2014, 11:07:10 PM by J_Speegle »
Offline GT500KR
  • Charlie Ping
« Reply #21 on: September 30, 2014, 11:46:18 PM »
Good point. it's just a for sale thread. Sorry.
« Last Edit: October 01, 2014, 09:35:49 AM by GT500KR »
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
Offline lscman
« Reply #22 on: October 01, 2014, 10:54:09 AM »
Jeff,sure glad you try and keep all these people who just like to see their posts on line as they have nothing better to do then write all over someones ads with stupid comments...Please erase them all!
« Reply #23 on: October 01, 2014, 12:15:14 PM »
Have a few NOS 289 Hipo crankshaft bolt washer and C alternator pulley spacers if anyone needs one?...Crank washer is $50 and alternator spacer is $25 plus the ride
Let's be blunt. It is a fact that Ford sold replacement parts, identified sometimes as NOS, that were not the same as original factory. It is a fact that there are unscrupulous sellers since the beginning of time. If a potential buyer asks a pertinent question about a part, the seller should provide an appropriate answer. To the specifics - there is more than one crankshaft bolt washer. Many of us that are fortunate enough to have a 64-67 Mustangs with the 289 HP engines know what the differences are. Others do not. That is the whole question. You put up for sale a specific part. A question of authenticity was asked. You got evasive. The thread got a bit off topic about the specific design of the washer. At last count there were three thicknesses mentioned. All you needed to do to keep this thread under control was to provide a thickness of the washer. You did not. Now you try to "sweep it under the rug". Why?
