Author Topic: 1970 Mach 1 rocker moulding/Side cladding Main Thread  (Read 16424 times)
Offline Kdclem
Re: 1970 Mach I Side Cladding Details
« Reply #30 on: January 05, 2021, 03:52:44 PM »
I'm posting a couple of pictures here hoping someone may have more detail on the hardware that holds the cladding together.  The one pdf file is from Osborn.  The bubble call outs are difficult to read.    The other photo is the piece that holds the cladding to the door.  I have 2 of them and need 12.  I cannot find this wire spring connector in the Osborn catalog either.  Ideally I'm looking for a complete list of hardware for the Cladding.  Thanks in advance.
Offline rickmustang
« Reply #31 on: January 20, 2021, 11:59:36 PM »
AMK has most of the cladding hardware. At least they did when I restored mine. This was probably the most tedious parts to restore on my Mach.
1970 black R-code 428 4-speed Mach 1
Built in San Jose mid-October 1969
1971 Mach 1 429 CJ Auto
Offline BlackMcode1970mach1
« Reply #32 on: January 21, 2021, 09:12:40 PM »
i to will need cladding hardware.
ive not found a kit for it. do i have to purchase seperate hardware?? mark
Offline alanmac
« Reply #33 on: February 05, 2021, 04:09:43 PM »
It needs to be stripped, polished then replated a fairly expensive endeavour
Cladding was originally done in a dark argent not black
Going to merge this thread with an earlier one to keep things together and to make it easier for others to find information using the search feature
I had mine restored by King of Trim in CA.  All road rash and dents removed polished and then anodized with the correct chemistry.  They turned out beautiful.  My trim is not painted to OEM paint color, either is my hood stripe.
« Last Edit: July 16, 2022, 03:49:20 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Offline silverelvis69
Rocker molds - Dark argent
« Reply #34 on: July 09, 2022, 05:01:43 AM »
Hi All,
I am in the process of restoring my rocker molds and understand this is in color of dark argent.
Would this be gloss or satin?
Many Thanks
San Jose built
11/69
Dark ivy green metallic
Ps A/c
Re: Rocker molds - Dark argent
« Reply #35 on: July 09, 2022, 05:38:37 AM »
It's a satin/egg shell looking finish like most argents were
Our largest thread on the subject of 70 Mach I side cladding and where I will likely attach this thread
https://www.concoursmustang.com/forum/index.php?topic=909.15
« Last Edit: July 09, 2022, 05:43:21 AM by J_Speegle »
« Reply #36 on: July 09, 2022, 05:42:19 AM »
Don't forget the black out detail behind the cladding applied on the Mach I's before the cladding was attached. Differed slightly depending on the car assembly plant.
Thread on that
https://www.concoursmustang.com/forum/index.php?PHPSESSID=caqf1ev6su2cq63466c9khi732&topic=656.msg3306#msg3306
« Reply #37 on: July 10, 2022, 05:45:26 AM »
Thanks Jeff for this. Good to know and will do.
San Jose built
11/69
Ps A/c
Re: 1970 Mach 1 rocker moulding color?
« Reply #38 on: July 12, 2022, 04:28:23 AM »
Does anyone have the code for this dark argent? is it DDL33053??
Also is Deep argent the same beast?
Thank you
« Last Edit: July 12, 2022, 05:05:25 AM by silverelvis69 »
San Jose built
11/69
Ps A/c
