Author Topic: Generator heat shield - 6 Cylinder  (Read 7167 times)
Offline 64rustang
  • Holland Patent, NY
Re: generator heat shield
« Reply #15 on: August 20, 2014, 12:50:00 PM »
Jeff,
For those of us who don't have access to that publication, can you provide us with a brief synopsis regarding 6 cylinder cars?
Leo
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRAN
 65A        D        46       27E      22       3        6
VEHICLE WARRANTY NUMBER
5F07U148XXX
« Reply #16 on: August 20, 2014, 06:24:06 PM »
Jeff,
Unfortunately Bob wrote the book focusing on V8 engines only all the way back into the early 60's so no specific reference to 6 cylinders. Though some of the logic of why they were used on the V8's might apply directly to 6 cylinders. His word - " Durign 1964, generator shields (a) were used on some non-A/C engines (shown here on a 289 HiPo). Photos of original engines suggest that the shield was introduced mid-1964 production, but still not all non-A/C engines appear to have gotten them........"   Lower down he references that many engines continued to be equipped with just the slip on rear rubber boot with no larger outer shield like in the earlier years. Suggesting that it was one or the other as factory
Taken from page 4-51 Mustang & Ford Small Block V8 1962-1969 Vo i & II
Just sharing
What I found interesting is that all the different types of boots and covers shown so far are illustrated in the book
Offline DM_1964
« Reply #17 on: August 20, 2014, 10:32:11 PM »
I think there is some debate over how accurate Bob's quote is as it seems the general population on the forum say for non A/C then it would've had been fitted with a heat shield...
When I asked the question I received the following info from a fellow forum member/admin "The general rule is that cars with A/C and K codes did not have the shield, all others did." ;)
Regards,
Dom
Offline DM_1964
« Reply #18 on: August 21, 2014, 10:15:37 PM »
the two '64 gen pages in Bob's book...
Regards,
Dom
Offline 64rustang
« Reply #19 on: August 22, 2014, 10:58:50 AM »
Thanks for sharing!  Unfortunately, I don't think we have a definitive answer to the original poster's question.  If we take the MCA rules literally along with the other information circulating, then non a/c 6's are supposed to have a heat shield.  It seems we are having trouble finding evidence to support this.  I find it hard to believe with the quantity of 6's produced, we haven't found a bunch of original examples with a heat shield, or even 1.  I'm beginning to get the feeling the 6's never had heat shields.
 65A        D        46       27E      22       3        6
5F07U148XXX
« Reply #20 on: August 22, 2014, 02:31:27 PM »
It wouldn't be the first time a 6 cyl detail was overlooked in the MCA rules.  I've personally been responsible for making that error in the past... when we added the negative battery cable clamp required for 64.5 cars... only V8 had them.
But, back to O/T, it does seem like it would be something that there would be more evidence of if it was common practice.  6 cyl cars were usually in the 30-40% range of production totals.
Re: Generator heat shield - 6 Cylinder
« Reply #21 on: August 22, 2014, 08:50:28 PM »
If we're going to try and clarify the 6 cylinder generator detail I guess we should discuss if the "heat shield" is the metal and rubber fixture or if it includes the "rubber rear boot" style.   Know how detail and specific we have to get when using only words to describe this sort of detail - just a thought  8)
By the way changed the original posters title to clarify the focus was only the 6 cylinder
« Reply #22 on: August 22, 2014, 10:40:15 PM »
Thought the rubber boot was used on all generators, main item in question would be the metal shield.
