You did good. Ok
Radiator cap is aftermarket - Right
Master cylinder should be black semigloss, not natural - It can be either
Fan belt routing decal appears to be missing - Right
Battery is aftermarket - Right
Starter solenoid appears to be aftermarket (can't tell from this angle) - Looks to be
Radiator is aftermarket - Right
Water pump is the newer "tan" one instead of the old "Black" one - I know you meant Power Steering pump
Decal is missing on the overflow tank - Right
Hood blanket appears to be missing - Right, and TOUGH to Find for 79-82!
Dipstick should be blue, I believe - Dipstick is correct
Brake cap is not "yellow" plated, or black - It should be black
Air cleaner has been repainted the wrong color (with overspray I might add) - the vacuum motor should be yellow plated
Radiator hose clamps are aftermarket, not pedestal _ we need to get some of these, how is Fox Resto doing on these??
Belt tensioner is painted black, instead of natural - It is correct at a flat blackish color
Coil is in the wrong place (you can tell because there are marks on the DS strut tower where it used to be) - It is in the right location
Wiper motor should be the black 1979-1983 one, not the 1984-86 one - I think that one is correct, black paint is wearing away
Some of the hoses are not Motorcraft, including the radiator and primary power steering lines - Right, and again tough to find
Intake "warmup" hose is aftermarket, and should also be flat black - Right
Hood prop is not painted the body color -ahh 79-82 MCA Rules states it should be black
Ignition module is either aftermarket, or the white Motorcraft decal is missing - I think you are right, hard to tell on picture
Good Job and also remember the 'blue distributor cap' and I will post a correct motor below.
