Author Topic: Calling MCA Judges what is wrong with this engine bay 79 5.0  (Read 5296 times)
Offline 79mustangcobra
« on: January 06, 2012, 05:09:57 PM »
This is a nice 'driver' engine bay, but if you were judging it what do find wrong?  I will post the answer's later on.  I just think it is good for us to know about this.
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
MCA #70281 -  79-93 MCA Concours Judge
Proverbs 3:5-6
Offline bill@wemc.net
Re: Calling MCA Judges what is wrong with this engine bay 79 5.0
« Reply #1 on: January 07, 2012, 12:02:03 PM »
How about this one?
Offline 85GTTops
« Reply #2 on: January 07, 2012, 04:21:32 PM »
Well I'm no expert on these, but for starters (assuming this is an 82 4.2L V8 due to the DS air intake hole):
  • Radiator cap is aftermarket
  • Master cylinder should be black semigloss, not natural
  • Fan belt routing decal appears to be missing
  • Battery is aftermarket
  • Starter solenoid appers to be aftermarket (can't tell from this angle)
  • Radiator is aftermarket
  • Water pump is the newer "tan" one instead of the old "Black" one
  • Decal is missing on the overflow tank
  • Hood blanket appears to be missing
  • Dipstick should be blue, I believe
  • Brake cap is not "yellow" plated, or black
  • Air cleaner has been repainted the wrong color (with overspray I might add) - the vacuum motor should be yellow plated
  • Radiator hose clamps are aftermarket, not pedestal
  • Belt tensioner is painted black, instead of natural
  • Coil is in the wrong place (you can tell because there are marks on the DS strut tower where it used to be)
  • Wiper motor should be the black 1979-1983 one, not the 1984-86 one
  • Some of the hoses are not Motorcraft, including the radiator and primary power steering lines
  • Intake "warmup" hose is aftermarket, and should also be flat black
  • Hood prop is not painted the body color
  • Ignition module is either aftermarket, or the white Motorcraft decal is missing
How'd I do?
« Reply #3 on: January 09, 2012, 12:14:05 PM »
You did good.  Ok
    Radiator cap is aftermarket - Right
    Master cylinder should be black semigloss, not natural - It can be either
    Fan belt routing decal appears to be missing - Right
    Battery is aftermarket - Right
    Starter solenoid appears to be aftermarket (can't tell from this angle) - Looks to be
    Radiator is aftermarket - Right
    Water pump is the newer "tan" one instead of the old "Black" one - I know you meant Power Steering pump
    Decal is missing on the overflow tank - Right
    Hood blanket appears to be missing - Right, and TOUGH to Find for 79-82!
    Dipstick should be blue, I believe - Dipstick is correct
    Brake cap is not "yellow" plated, or black - It should be black
    Radiator hose clamps are aftermarket, not pedestal _ we need to get some of these, how is Fox Resto doing on these??
    Belt tensioner is painted black, instead of natural - It is correct at a flat blackish color
    Coil is in the wrong place (you can tell because there are marks on the DS strut tower where it used to be) - It is in the right location
    Wiper motor should be the black 1979-1983 one, not the 1984-86 one - I think that one is correct, black paint is wearing away
    Some of the hoses are not Motorcraft, including the radiator and primary power steering lines - Right, and again tough to find
    Intake "warmup" hose is aftermarket, and should also be flat black - Right
    Hood prop is not painted the body color -ahh 79-82 MCA Rules states it should be black
    Ignition module is either aftermarket, or the white Motorcraft decal is missing - I think you are right, hard to tell on picture
Good Job and also remember the 'blue distributor cap' and I will post a correct motor below.
« Last Edit: January 09, 2012, 12:21:14 PM by 79mustangcobra »
2P Red and 1C Black
Proverbs 3:5-6
« Reply #4 on: January 09, 2012, 12:20:16 PM »
Here is a 300 Mile 79 Pace Car Motor to compare
2P Red and 1C Black
Proverbs 3:5-6
Offline 85GTTops
« Reply #5 on: January 09, 2012, 12:22:41 PM »
Nice!
Matt mentioned the clamps are still in the works. I haven't spoken to him in a while (like a month LOL!).
I believe the clamps are similar to those on Gen I and II Mustangs. There is a source for these but I haven't grabbed them yet.
Also, as far as the belt tensioner goes, is that "black" color an electroplating? Here's a NOS one:
« Reply #6 on: January 09, 2012, 12:27:47 PM »
Jeff you are right, I don't know if it is electroplating.  I know my NOS one I have I sprayed WD-40 on it to preserve it and the Black popped!  I need to get those clamps, lol!
« Last Edit: January 09, 2012, 12:30:40 PM by 79mustangcobra »
2P Red and 1C Black
Proverbs 3:5-6
« Reply #7 on: January 09, 2012, 12:32:30 PM »
These are the clamps, right
2P Red and 1C Black
Proverbs 3:5-6
« Reply #8 on: January 09, 2012, 12:34:48 PM »
Here is a picture of a 79 108 Mile Turbo 4
2P Red and 1C Black
Proverbs 3:5-6
