I'm just starting to restore an original 1964-65 rally pac and I'm already running into a few questions. First I have dissassembled the pac and one of the first items to tackle is a wiring kit replacement as the wires have been cut. Anyone have any tips for this?? I see they offer a replacement set, are they decent?? Also, I want to polish and clean up the original lenses. Any products or tips in this area??? One big question is how do I remove the clock stem?? I definitely do not want to break anything!!
Next, looks like the tach might have come out before as one of the screws is not original?? Guess there is no way of knowing and hopefully the tach works, (as it seems there is no way of bench testing the tach correct??)
Lastly, (for now), should the rally pac "words" on the plastic center be painted silver or left black? These do not look like they have ever had any paint on them..
Ohh, and what type of paint is a good touch up and match?? Manufacturer and type (semi flat,etc). This is ofcourse a black rally pac, pics to follow in a minute. Thanks for any replies!!!!!
I'll tackle your questions in order starting with the wiring. The rally pac wiring repair kit worked very well for me. One thing to note is that the repair kit provides you with quite a bit of wire so you should measure the approximate amount you'll need and trim it to start. Leave yourself a little bit extra to work with (you can always tuck it up under the dash). In addition, the underdash harness is reasonably long as well. To facilitate the repair did the following:
Wiring1- Stripped the end of both wires
2 - Ran a length of shrink tubing up on of the end of the wires (to protect / seal the repair)
3 - Weaved the two end of copper wire into one another and soldered it
4 - Placed the shrink tubing over the repair and applied heat to shrink it
5 - Wound electrical tape over the repair to duplicate the look of the harness from the factory
The bullet connector ends on the harness fit nice and snuggly together with one another. PS - While you have everything apart you'll want to replace light bulbs too.
Lens - I found the reproduction lens to be more than adequate and didn't both to try to save my extremely brittle and yellowed originals. You could try to use a headlight polishing kit but I'm not sure what results you could achieve
Scripted Rally Pac (in the center) - The words rally pac in the center should be chrome in color (not silver). There is no chrome paint I found. Instead I bought a thin sheet of chrome from a hobby / model store and carefully applied and trimmed it with an exacto knife. It was tedious work but I was pleased with how it turned out.
Paint - I was lucky in that my rally pac's paint (also black) was in pretty good condition. It just need to be touched up. The key is to duplicate or not spoil the crinkle camera case style finish on the rally pac. I gently cleaned my rally pac (allowed to dry thoroughly) and then with a combination of Krylon Satin Finish and Krlyon Textured Finish (Outdoor Spaces) I was able to duplicate the original sheen and not fill in the texture. I applied 4 very light coats of paint (2 coats satin finish and 2 coats textured finish). I turned out very nice. I carefully masked off the chrome on the underside of the hoods to avoid any overspray.
I've attached some pictures of the Rally Pac post paint (I couldn't find my "before" photos).
Good Luck with your resto!
Regards,
Ron
