Author Topic: Early San Jose C code Correct ignition coil location?  (Read 6089 times)
Offline 1965GTFB
« on: May 01, 2015, 01:19:00 AM »
Early 67 FB, San Jose built, 289 2v
What is correct location(s) for ignition coil?
On the intake, Pass side, point forward?
On the pass side head by dip stick?
On the intake DS point to rear?
« Last Edit: July 26, 2022, 05:43:17 PM by J_Speegle »
Re: Correct ignition coil location?
« Reply #1 on: May 01, 2015, 08:53:42 AM »
Intake PS pointing forward on a thermactor equipped car, pass side head by dip stick for non-thermactor.
Offline Ralf
Mustang 67 Position of Ignition Coil San Jose C code
« Reply #2 on: February 20, 2016, 10:33:44 AM »
Hi,
I'm interested to know the position of the ignition on a 289 cui, 1967, A/C.
Mine is vertical mounted along the intake manifold.  :-\
Great to post some pictures. Ralf
« Last Edit: July 26, 2022, 05:44:07 PM by J_Speegle »
Re: Mustang 67 Position of Ignition
« Reply #3 on: February 20, 2016, 10:46:48 AM »
Hi,
COIL? Ignition coil?
The Thermactor equipped cars have the coil mounted on the intake, others on the front side of the passenger's head.
Offline Ralf
« Reply #4 on: February 20, 2016, 11:08:34 AM »
Not mine, but as an example (in my car the same position):
Read correctly your post, for all A/C cars the position is like shown below.
« Last Edit: February 20, 2016, 11:11:27 AM by Ralf »
Re: Mustang 67 Position of Ignition Coil
« Reply #5 on: February 20, 2016, 05:31:56 PM »
Hi,
You don't mention if your car is a Thermactor equipped car or not but in this case its not going to matter
Guess you missed this example in doing a search ;) Visible in picture #2, #3 & #5  to start with
http://www.concoursmustang.com/forum/index.php?topic=8272.msg47869#msg47869
Yours would be the same  IMHO
« Last Edit: February 20, 2016, 05:34:18 PM by J_Speegle »
Offline Ralf
« Reply #6 on: February 21, 2016, 04:41:09 AM »
No, don't have such a thing, despite my car was born end of 66 in CA.....thermactor=smog pump, I guess.
May be dismantled, or was simply not there.
« Reply #7 on: February 21, 2016, 05:05:25 AM »
Being built doesn't automatically = Thermactor the DSO does in 99.5% of the time
In any case the answer is in the pictures in those links I provided
Offline Ralf
« Reply #8 on: February 21, 2016, 05:19:51 AM »
DSO 75
In case of disassembly, there must be some plugs/screws in the cylinder header. I'll look....
« Last Edit: February 21, 2016, 05:21:58 AM by Ralf »
« Reply #9 on: February 21, 2016, 05:42:29 AM »
DSO 75
Should not normally find any with that DSO unless the engine or heads have been replaced
75 typically means no Thermactor system in 67
Offline Ralf
« Reply #10 on: February 21, 2016, 06:05:48 AM »
Ok, thats a good statement to me. Means I don't have one (even the car is a SJ built)
Because I have read that all California (66/67) cars had to have this equipment due to law regulations in this State.
« Reply #11 on: February 21, 2016, 07:11:08 AM »
Ralf, not all cars built in California were delivered to California.  In your case the car was ordered through the Phoenix, Arizona district sales office.  Arizona did not require thermactor.  It would make sense that the car would be built in California rather than on the other side of the country when you consider shipping costs.
Offline Ralf
« Reply #12 on: February 21, 2016, 08:44:40 AM »
My engine....only handy quality. :-[
« Last Edit: February 21, 2016, 09:34:02 AM by Ralf »
Offline Ralf
Re: Mustang 67 Position + colour of Ignition Coil
« Reply #13 on: October 30, 2017, 05:49:41 AM »
Coming back to this one.
What is the original colour (+ eng/part. number) of the early 67 ignition coil (in german Zündspule)?  Yellow cap, black body?
Thx
Ralf
« Last Edit: October 30, 2017, 09:00:59 AM by Ralf »
« Reply #14 on: October 30, 2017, 09:28:54 AM »
Thx
Ralf
Yes. a "mustard yellow" of sorts. There was a thread on repainting older coils to freshen them up. There is also a date stamping on original coils, often covered up with the mounting bracket.
