Author Topic: Coil Bracket  (Read 4075 times)
Offline Brian Conway
Coil Bracket
« on: May 29, 2015, 10:58:10 PM »
Is this coil bracket specific to a time frame or an engine ?  Thank you.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Online ruppstang
Re: Coil Bracket
« Reply #1 on: May 29, 2015, 11:40:52 PM »
It was first used in 68. I am not sure for how long after 68. The angle cut on is there to give clearance on the RH side of the manifold where it was mounted.
Marty
Re: Coil Bracket
« Reply #2 on: May 29, 2015, 11:49:02 PM »
The locating hole in the bracket typically indicates that it is a 64/65 vintage. The coil would have a raised bump to orient the coil properly in the bracket. That type of coil was not used after 1965 .I believe the brackets with the holes were still used even after the coils were changed but were phased out in the early 66 production.
Online jwc66k
Re: Coil Bracket
« Reply #3 on: May 30, 2015, 12:47:50 AM »
Per Mannel (pg 6-30 fig c), intake manifold or cylinder head. If the notch is on the other side, it's cylinder head only.
Offline markb0729
  • South Jersey
Re: Coil Bracket
« Reply #4 on: May 30, 2015, 01:52:33 AM »
Pulled that exact bracket off of a 260 out of a 64 1/2 coupe.  It was located on the intake manifold.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline Richard P.
Re: Coil Bracket
« Reply #5 on: May 30, 2015, 09:02:14 AM »
1
+ 1
Online ruppstang
Re: Coil Bracket
« Reply #6 on: May 30, 2015, 09:03:30 AM »
Ok I learned some thing I will have to look closer at the 68 and see the difference.
Thanks Marty
Re: Coil Bracket
« Reply #7 on: May 30, 2015, 05:34:05 PM »
Thanks fellas.  What I think I have learned ?  The angle cut to the bracket indicates for use on an FE intake manifold.  The FE intakes are indexed so the coil in this bracket is parallel to the left valve cover.  The hole indicates it was for use with a 64-65 coil.  So not for a Mustang ?  Brian
San Diego, Ca.
Offline suskeenwiske
  • 214-347-3628
Re: Coil Bracket
« Reply #8 on: May 30, 2015, 07:42:19 PM »
My previous Dearborn '65 Coupe with 289, looking at photos I took, had the notch reversed and was mounted on the Cylinder Head; no Locating Hole in the bracket.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Re: Coil Bracket
« Reply #9 on: May 30, 2015, 10:15:33 PM »
The coil bracket on my 65 GT; is mounted to the R. head, has the angle cut on the downward side and has no hole in the front.  So a guess would be that the dimpled/indexed coil was no longer in use ?  Brian
« Last Edit: May 30, 2015, 10:24:31 PM by Brian Conway »
San Diego, Ca.
Re: Coil Bracket
« Reply #10 on: May 30, 2015, 11:04:35 PM »
.............The hole indicates it was for use with a 64-65 coil.  So not for a Mustang ?
Would not go that far IMHO  but rather not a normal feature seen the majority of very early cars.
Do have some pictures from 65 with a bracket with that hole. Believe that there is at least one prior discussion of these brackets in the 65-66 Section of the site.
Comes up fairly often on any number of sites - but as mention, not typical or normal
Offline markb0729
  • South Jersey
Re: Coil Bracket
« Reply #11 on: May 31, 2015, 02:41:24 AM »
Here's some pics of the coil bracket I took off the intake manifold of a 64 1/2 260, 2V Mustang Coupe.
« Last Edit: May 31, 2015, 02:44:04 AM by markb0729 »
