Author Topic: 69 428 CJ - PS Hose Protective Sleeve  (Read 4293 times)
Offline Vcode
« on: June 10, 2015, 09:30:51 AM »
Anybody have a picture showing where the PS hose protective sleeve goes?
Thanks.
« Last Edit: June 10, 2015, 05:57:06 PM by J_Speegle »
Re: PS Hose Protective Sleeve
« Reply #1 on: June 10, 2015, 09:38:03 AM »
what year?? which engine?? a/c or no a/c??
Offline Vcode
« Reply #2 on: June 10, 2015, 01:14:34 PM »
1969 428 no A/C
Offline Sean C. Gearty
  • 1969 San Jose GT
« Reply #3 on: June 10, 2015, 01:48:39 PM »
If you are asking about the foam that goes over the power steering return and cooler lines, I have a couple of images that may help. There is one picture I don't have on file, that you will need to see as it is just where the blue paint daub is, that is a space where a plastic clamp goes to secure the two lines together, and another portion of foam follows that up. There is a picture on Jack's website that shows the clamp if you are not familiar with them.
http://www.deadnutson.com/catalog/item/4065497/4706481.htm
If I get a chance later, I will try and forward an image where the clamp is. Hope this helps.
Offline Vcode
« Reply #4 on: June 10, 2015, 05:10:24 PM »
Thanks for posting the pictures. Those will be a big help.
I knew about the clamp - but my car was built in May so I guess it wasn't used.
So if the clamp wasn't used - is it just one long piece or still two pieces?
Do you know what the length dimension is?
Back in the late 70's early 80's I got a complete PS system form a 1969 351 car with 14,000 miles - I seemed to remember the sleeve was in two pieces - but I don't remember any clamp - but that was a 351 car.
Dale.
  • 1969 San Jose GT
« Reply #5 on: June 10, 2015, 05:26:24 PM »
Dale,
you may have to rely on some of the more experienced on this forum with May production and what facility your car was produced. I had a May produced big block Dearborn 69 Mustang that did have that power steering clip as well.
All the Best!
Offline Vcode
Re: 69 428 CJ - PS Hose Protective Sleeve
« Reply #6 on: June 10, 2015, 09:47:14 PM »
Sean,
Thanks for that info on your May Dearborn car with the clip.
Mine is a Metuchen built.
I think Ed had one of those clips on ebay a couple of weeks ago.
Do you have any info on the P/S Hose Rubber strap that Max sells (F-521) for the 390/428?
Dale.
« Last Edit: June 10, 2015, 09:55:39 PM by Vcode »
« Reply #7 on: June 11, 2015, 12:47:42 AM »
got more plastic hose holders left & the foam hose protector wasn't on all cars depending onwhen built as its more of a later 69-70 thing . the pump foam is 9'' & cooler hose is2-5'' foam
Offline Vcode
« Reply #8 on: June 11, 2015, 07:28:47 AM »
PM sent.
Offline DragPack69
« Reply #9 on: June 13, 2015, 04:00:00 PM »
Is this hose available or do I need to re-use the old stuff.
Both of mine are the same length, about 6 1/8 long.
BTW, my car is 5/15/69 dearborn buil;t and had/ has both .
clip and foam.
Offline Vcode
« Reply #10 on: June 19, 2015, 09:26:46 AM »
clip and foam.
Mustangs Unlimited sells it.
http://www.mustangsunlimited.com/search_sorted.asp?Keywords=9371P&x=39&y=10
« Reply #11 on: June 23, 2015, 06:38:21 PM »
Has anyone used this .... does it look correct for the application?
At one time I believe some were just going down to the GM dealerships and purchasing it there. Sorry don't have the modern application not part number
Offline Vcode
« Reply #12 on: June 30, 2015, 11:21:00 AM »
Here's the sleeve that Mustangs Unlimited sells.
It's about 21" long with a wall thickness around .150"
Offline rcgt350
« Reply #13 on: March 04, 2017, 02:11:16 AM »
Would a 70 Boss 302 use the Foam on the Return hose for the Power Steering? If so, how long is it and where about should it be placed?
Randy
1967 GT 350 W White
1970 Boss 302 GG Restoration in progress
2012 Boss 302 C Orange
1930 Ford Model A 4 Door Deluxe Town Sedan
« Reply #14 on: March 04, 2017, 11:06:06 AM »
I sent an original piece of this foam to Daniel Carpenter back years ago & had him make the foam since this foam p/s hose protector always stretches & swells from engine & p/s fluids leaks & exhaust heat. I told him to market & sell it in 21'' lengths as that would fit all boss 302 & 429s & 428 cjs & other ford cars & the buyer could cut it to correct lengths depending on the car it is being used on. I only found one piece of this foam nos & it had a c7az ford # id tag on it so it was being used back in 1967 on other ford cars as I have found this foam on hoses in other ford p/s kits in old ford dealerships back in the 80s & 90s when I made obsolete parts buying dealership trips.  Dragpack69 you cant go by old used fluid soaked foam hose lengths since they stretch & swell badly over the years & fall apart.  I got my original lenghts from low mile cars & new take off p/s setups taken from cars made into drag cars back in 69 when they were new.  Also around 1971 or so I see ford changed over to a harder rubber type hose protector that held up better to the elements.
