Author Topic: 69 Shelby Rear End  (Read 2467 times)
Offline ddonzella
69 Shelby Rear End
« on: June 16, 2015, 11:58:25 PM »
Have a 1970, (69) Shelby GT 350. How do I know if it is a 8 inch or 9 inch rear end and if it is a 28 or 31 spline rear end? Are all 69 Shelbys 31 spline 9 inch rear ends?
Thank you
Offline 69GT350H
Re: 69 Shelby Rear End
« Reply #1 on: June 17, 2015, 12:05:40 AM »
I'm going to say that all 69 Shelby's came with 9", and as its a GT350 its a 28 spline. If it were a GT500 it might have had a 31 spline as that is what my 69 Mach I 428CJ had. But I am sure there are others here that could give you a better answer. Thats why I love this place!   ;D
Offline Brian Conway
« Reply #2 on: June 17, 2015, 10:51:40 AM »
The 8" and 9" differential/axle housings and axle shaft ends are configured differently.  If still in place the tag will have all the Information. A search in the 69-70 section may help or post a picture and someone will respond ?  This picture is of a 31 spline axle end.  Brian
« Last Edit: June 17, 2015, 01:07:18 PM by Brian Conway »
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
Offline ddonzella
« Reply #3 on: June 17, 2015, 12:21:30 PM »
Thanks!
Offline 1970shelbyguy
« Reply #4 on: July 31, 2015, 06:28:54 AM »
on a 9 inch you can't acess btm bolts with a socket  - just "google" it.
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
« Reply #5 on: July 31, 2015, 08:11:37 PM »
Thank you
All 69/70 Gt350's had a 9 inch rear end . 69/70 GT350 had 28 spline rear axles and GT500 had 31. I hope this helps.
« Reply #6 on: August 01, 2015, 12:46:14 AM »
Guess the easy DIY would be to look at the restoration thread of the G350 on this site and see if yours matches what was shown in those pictures ;)
Another way to identify the difference is the machined sections/surfaces of the third member housing since you can often get a deep socket on every bolt - just not always perfectly inline with the stud
Might help with a number of your  questions
« Last Edit: August 01, 2015, 03:40:13 PM by J_Speegle »
