Author Topic: 70 - Firewall clamp for wire harness at Blower Motor  (Read 1714 times)
Offline blackjadeboss
« on: July 20, 2015, 08:03:41 PM »
I am looking for a source for the rubber coated J clamp that held the wire harness for the alternator, voltage regulator and starter solenoid.
It attached to the outer top blower motor stud.
Has anyone sourced that new ?
Thanks in advance.
Keith
« Last Edit: July 21, 2015, 02:27:38 PM by J_Speegle »
Re: Firewall clamp for wire harness
« Reply #1 on: July 21, 2015, 12:01:40 AM »
What year?
« Reply #2 on: July 21, 2015, 07:41:26 AM »
It's a 70, and in fact I should have posted this in the Boss, or Dearborn section.
My bad.
Offline rockhouse66
« Reply #3 on: July 21, 2015, 08:47:25 AM »
This is the clamp you are looking for?  I see this routing on most Dearborn cars but some are clipped under the brace like is common on a Metuchen car.
'66 GT FB
« Reply #4 on: July 21, 2015, 11:11:19 AM »
Indeed it is!
Re: 70 - Firewall clamp for wire harness at Blower Motor
« Reply #5 on: July 21, 2015, 02:28:26 PM »
Just picked them up at wrecking yards or made them from scratch. Believe they are the same as the ones used for the AC vacuum lines normally directly above on AC cars (another source)
Fix the title to represent what you were asking about ;)
« Reply #6 on: July 21, 2015, 02:46:44 PM »
Thanks Jeff.
« Reply #7 on: July 22, 2015, 10:29:03 AM »
the a/c line strap holder is smaller  but you can find that size strap holder under dash wiring harness.
« Reply #8 on: July 22, 2015, 02:43:59 PM »
The heater motor one is that wide??  Thanks for the correction for the OP
« Reply #9 on: July 22, 2015, 02:59:48 PM »
I have both ... so I can measure. My original f/w piece is pretty ugly.
