Author Topic: 65 Air conditioning hole questions  (Read 5966 times)
Offline 66RavenGTCoupe
« on: August 10, 2015, 05:09:42 AM »
Hi guys,
Looking for help on my wife's Sept 64 SJ convertible that I am installing a factory air con unit into.
I've seen a few fire walls at the only Mustang wrecking yard in the state (Victoria, Australia) and it seems that the two air con hose holes are one above the other unlike on my Dec 65 NJ car where there is a larger horizontal oval punch out panel. Is this correct for 64's to have these two holes. What's funny is that they were all in the same place but they all looked like they had been cut out with a hole saw and not factory punched. Did Ford use a template on the firewall for the 64 1/2 - 65's to drill these out maybe?
I have a patch panel for the fire wall but was also wondering what the hole sizes were for the hoses to go through the radiator support panel and if anyone can supply photos or measurements or a template for correct locations?
Thanks.
« Last Edit: August 10, 2015, 08:31:32 PM by 66RavenGTCoupe »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: 65 Air conditioning hole questions
« Reply #1 on: August 10, 2015, 12:34:31 PM »
Early '65 cars with A/C had the 2 holes one above the other, unlike the later style.  Most holes like this were not punched, contrary to popular belief, but rather a regular hole saw used.
« Reply #2 on: August 10, 2015, 07:14:21 PM »
Thanks Charles,
So would the vertical holes be correct for a Sept 65 SJ car? Do we know the cut off date?
Edit: this should read Sept 64 SJ car.
Daniel.
« Last Edit: August 10, 2015, 08:33:12 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #3 on: August 10, 2015, 08:09:21 PM »
Are you certain it was September 65 not September 64? Interior firewall pads are different between the different periods. Believe there are three San Jose style ones that were used
I've got the horizontal punch out starting on cars with projected build dates around the first week of April 65 at San Jose (example 5Rxxx206432)
End of April projected date example - just because it was easier and a better picture
« Last Edit: August 10, 2015, 08:25:23 PM by J_Speegle »
« Reply #4 on: August 10, 2015, 08:29:06 PM »
Correct Jeff,
My mistake. It's a Sept 64 SJ build. Thanks. I'll edit the question.
Any info on the radiator support panel holes at all?
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #5 on: August 10, 2015, 10:17:33 PM »
Thanks Charles,
Daniel.
Yes, changeover was later, have seen SJ cars in Feb '65 with the stacked holes.
Offline ChrisV289
« Reply #6 on: August 11, 2015, 12:29:33 AM »
Here is a pic of my firewall AC hoses from the inside.  Schedule build date 10/29/64 SJ:
« Last Edit: August 11, 2015, 09:53:08 AM by ChrisV289 »
2009 V6 Mustang Coupe
« Reply #7 on: August 11, 2015, 05:19:24 AM »
Thanks Chris,
You wouldn't have pics of the holes on the Radiator support panel by any chance?
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline goumoun
« Reply #8 on: August 11, 2015, 08:11:57 AM »
I have this from a customer coupe scheduled build date 01 July 64 Dearborn. Unfortunately I did not take the upper hole but I can tell you it is in the same location as any 65. What changes is the hole in the firewall. Here there is one large hole for two hoses and wire.
The whole AC install looks factory. i.e. when looking at sealant marks but cannot say for sure 100%. No trace of a holesaw or from a file on the firewall, just a clean cut. Considering the location of this hole on the firewall, it is difficult to make it with engine and pedal support installed, feasible but not easy. This makes me think the firewall hole was drilled before the power train was installed.
« Last Edit: August 11, 2015, 09:09:20 AM by goumoun »
65A  K  25  15M  91  1  6
5F07A372xxx
« Reply #9 on: August 11, 2015, 11:33:13 AM »
I would have to say that is a dealer or owner installed setup.
Offline suskeenwiske
  • 214-347-3628
« Reply #10 on: August 16, 2015, 01:37:20 AM »
Thanks Chris,
These are some photos I took from a restoration I did 15 years ago. Holes were factory punched on this midyear '65 Dearborn Coupe.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
« Reply #11 on: August 16, 2015, 02:50:08 AM »
Thanks a bunch Ray. Any chance of getting the hole sizes?
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
  • 214-347-3628
« Reply #12 on: August 16, 2015, 02:17:12 PM »
I measured them at the time for future info but have lost track of all my notes; I actually need them for my current project as well.
I'll see what I can find...it's possible that I've asked this question on this forum...don't know for sure. If not, I'm sure someone out there has the answer for us both. If not however, buying the bushings and measuring them should give us the answer.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
Offline Richard P.
« Reply #13 on: August 16, 2015, 08:06:35 PM »
I think the hole size is the same as the ones used on your seat plugs under the car. Try your AC grommet in one of those holes.
Offline rodster
« Reply #14 on: August 16, 2015, 10:13:33 PM »
Top hole is punched at 1.25" on my 65 Dearborn coupe. Guessing both holes are the same?
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
