Author Topic: 67 rear tail light optional "ribbed" panels  (Read 1635 times)
Offline socalgt
« on: December 04, 2015, 07:02:41 PM »
I'll be installing the panels on a fastback that did not have them originally installed at the factory.  I see that the additional 4 holes required for mounting each panel(not counting the 6 existing holes from the tail light trim) appear to be in a straight line with the existing holes for the tail lights.(not so on the coupe/convertible)  I'm thinking of snapping a chalk line across the center of those holes from the left side to the right.  I believe that should give me the right line to drill the additional holes, after of course, measuring their distance.  Any thoughts on this....or suggestions for another method?
        Thanks...
Re: 67 rear tail light optional "ribbed" panels
« Reply #1 on: December 04, 2015, 08:11:15 PM »
Slap some masking tape where you think the holes will go. Use a pencil to mark the spot. Measure twice, drill once (measure once, stop, come back in and hour, start over).
« Reply #2 on: December 04, 2015, 10:26:09 PM »
I would make a paper template off the panels then place it on the taillight panel lining up the 6 tail light holes and check the fit around the gas cap.
Just a idea.
Offline socalgt
« Reply #3 on: December 05, 2015, 10:41:23 AM »
Thanks for the replies....I may try the template  idea.
« Reply #4 on: December 05, 2015, 12:28:32 PM »
+1
Posterboard helps keep things rigid while creating such templates. Paper is OK too, works good on flat surfaces. I have occasionally began with paper to begin the template and transfer my "draft" template onto the posterboard.  I often prefer to use posterboard when you get into multi-dimensional templates.
Offline travnemi
  • Travis Waters
« Reply #5 on: December 05, 2015, 10:45:02 PM »
I have a question, if going for the concourse driven class. Would it be a point deduction to put the rear tail light panels on if they are not on the Marti Report?
Travis
Travis Waters
Mine -
1967 Mustang GTA S Code, Fastback, San Jose, Built Dec. 13, 1966 (Thermactor)
Daddy / Daughter Project -
1967 Mustang S Code, Fastback, San Jose, Built Sept. 9, 1966
« Reply #6 on: December 06, 2015, 01:33:11 AM »
 Currently the MCA does not require a Marti report. I do not know about the other clubs. So as long as the grills were installed correctly with the correct hardware there would be no deduction.
