Author Topic: 67 200 ci with 4spd  (Read 2299 times)
67 200 ci with 4spd
« on: December 06, 2015, 11:59:21 PM »
I am working on a 67 200 ci with a 4spd. Where on the transmission would I find identification numbers? Would this 4sp work behind a 289ci? I intend to convert  the car to a 289 and was not sure if this transmission would work if I found a V8 bell housing.
Re: 67 200 ci with 4spd
« Reply #1 on: December 07, 2015, 06:22:48 AM »
I wish I could give you more than an "If memory serves" answer, but I believe the driveshaft differs on the inline 6 and the nput shaft is different too (fine splined clutch disc?) I might be mixing my thoughts with Falcon or other than a 67, so take this with a grain of salt. Not too many 200cid with 4 speed cars out there. Pretty sure the internal ratio is different in any case. None-the-less, I believe I was successful in the V-8 conversion using the inline 6 transmissions but the end result was "less than Concours".
« Last Edit: December 07, 2015, 06:26:52 AM by 67gtasanjose »
Offline GT500KR
  • Charlie Ping
« Reply #2 on: December 07, 2015, 08:46:36 AM »
You have a really unique car there, I would encourage you to leave it as it is. Too many 6cyl cars have been lost to conversions and scrapped. Personally, I enjoy seeing the ones that remain at shows. Important part of the Mustang story IMO.
Plus, gas won't be $1.75 a gallon for long.... ;)
« Last Edit: December 07, 2015, 09:04:35 AM by GT500KR »
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline WT8095
  • Dave Z.
« Reply #3 on: December 07, 2015, 09:14:17 AM »
I think it would be cool to keep the unique combination you have. If you want more power, check out http://classicinlines.com/. Easier to change back to concours if and when you decide to.
Dave Z.
Offline Richard P.
« Reply #4 on: December 07, 2015, 09:33:12 AM »
Is your 4 spd. transmission the Dagenham?
« Reply #5 on: December 07, 2015, 05:00:22 PM »
Would need to know what type of 4 speed it was.
Can't recall if I've ever seen a 67 4 speed 6 cylinder or even hearing of someone claiming to have one. More common (though still rare) in 65-66
Offline WT8095
  • Dave Z.
« Reply #6 on: December 07, 2015, 06:59:18 PM »
The In Search of Mustangs database (http://www.isomustangs.org) has the following data:
1967 Mustangs: 13,195
1967 + 200 I-6: 4,350
1967 + 4-speed: 149
1967 + 200 I-6 + 4-speed: 0
Yours is therefore 1 of 0!  :o  ::)
This would definitely be one to run past Kevin Marti. ISOM only has user contributions, not the entire set of production data.
Dave Z.
« Reply #7 on: December 07, 2015, 09:24:32 PM »
Mustang By The Numbers (Marti) lists no 4 speed I6's in 1967, although 11 of the 472,207 total Mustangs had a blank transmission tag that were I6's.  20 C codes also had blank transmissions.
« Reply #8 on: December 07, 2015, 11:37:06 PM »
Ok it is time I set the record strait on this one. I have old timers disease. Sometime  I can not see or think clearly. I bought this 67 T code coupe that had been in storage for 30 years because it was nearly rust free and had NOS parts included, plus it was reasonably priced. When I looked under the car it appeared to have a 4spd when I checked the tag I thought I saw 5 under transmission which is a 4spd. I looked through all of my Ford information and could not find how you could order a 4 spd with a 200 6cil.
To day I removed the door tag and put on my glassed and was embarrassed to a 3 in the transmission position instead of a 5, but that was the axel code. The transmissionand axel codes were shifted to the right and the 1 for a 3 spd manual was under the rivet. I pulled the engine and transmission yesterday so I could clean up and check the transmission for a tag or casting numbers. I thought someone may have put the Dagenham in the car. I found the tag and it read HEH CL it turns out it is out of a 66 Fairlane 390 GT So I guess there will be no problem with it holding up behind a 289.
Lessons learned never trust that it is original even if it has been stored a long time and wear your eye glasses.
I like building these cars and thought I would use some of my parts that are not good enough for a concours car and make a fun driver to sell and fund my GT350 restoration
« Last Edit: December 08, 2015, 09:23:06 AM by ruppstang »
