Author Topic: 67 390 oil sender  (Read 2574 times)
Offline preaction
67 390 oil sender
« on: December 12, 2015, 05:59:32 PM »
does anyone have a pic or part number for one of these, thanks Paul.
Re: 67 390 oil sender
« Reply #1 on: December 12, 2015, 06:48:29 PM »
Isn't there a couple of different ones?
One for the idiot light and one for the gauge?
Which are you looking for?
Offline preaction
« Reply #2 on: December 12, 2015, 09:11:46 PM »
Sorry, idiot light model.
« Reply #3 on: December 14, 2015, 09:12:34 PM »
So for 67 390 Mustangs with the Tach option the MPC shows that the replacement (and possibly the original) was marked with a #6 on the base - had a 1/4" - 18 pipe thread fitting and was assigned the part number C7AZ-9278-A if the car was built before April 1st 1967 which I think covers your car
This same part fit other 67 cars including 6 cylinder as well as other V8' so not 390 only piece
Checked but don't have a picture
« Reply #4 on: December 14, 2015, 10:09:15 PM »
The analog gauge style oil pressure sending unit can best be described as a large bell, compared to the much smaller idiot light version.
1967 can be identified from 1968 and later by the way the wire connects on top. 1967 has a small disc on top, and a flat wire connector slides over it.
1968 and later versions both had a threaded stud on top. The under hood wire connector was a boot style connector that fit over the threads.
You didn't ask, but the water sending units have the same kind of electrical connections for 1967, and changed 1968 and later too.
Look for a picture of the reproductions, they look virtually the same.
« Reply #5 on: December 15, 2015, 01:10:23 AM »
Analog gauge style of bell sender was used on 65/66 also .It used the threaded stud style like 68 and later.It seems like a one year 67 deal. The ones in 65/66 that i am familiar with were used on small blocks but they interchanged with the later cars too. The gauge and sender didn't care if it was a BB or a SB. Your comment on the water temp sender has me curious of what application used a spade type connector like the 67 oil pressure sender . All of the water temp senders I am familiar with on 67 SB and BB were the threaded stud style.
« Reply #6 on: December 15, 2015, 09:36:09 AM »
[  All of the water temp senders I am familiar with on 67 SB and BB were the threaded stud style.
[/quote]
Me too
« Reply #7 on: December 15, 2015, 10:58:27 AM »
if you need the bell type c7zz oil sender I have some nos
« Reply #8 on: December 15, 2015, 12:22:02 PM »
Son of a Gun, I don't know what I was thinking. You are right on the temperature sending unit. Should have checked before posting.
Re: 67 390 oil sender - TSB Article #1011
« Reply #9 on: February 07, 2016, 06:41:49 PM »
Was just scanning some TSB's for other threads and since this was in the same group as my focus thought I would post it here. Enjoy
« Last Edit: July 02, 2020, 06:21:51 PM by J_Speegle »
