Author Topic: 67 A/C compressor  (Read 2520 times)
Offline bazza
67 A/C compressor
« on: December 16, 2015, 03:21:17 AM »
Hi all, I have a very late Dearborn S code coupe. Factory A/C car, but missing everything under the hood. What sort of compressor would it have had??
How are they dated??
It currently has a low mount alternator, I'm guessing that is incorrect??
Any pics of the front accessories with belt and pulley arrangement??
Thanks.
67 Dearborn S code coupe Built 8/17/67
Offline GT500KR
  • Charlie Ping
Re: 67 A/C compressor
« Reply #1 on: December 16, 2015, 10:08:41 AM »
Welcome to the site.
The search feature can answer many of your questions. I found this thread that might be helpful for you.
http://www.concoursmustang.com/forum/index.php?topic=11964.msg72358#msg72358
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #2 on: December 16, 2015, 12:53:13 PM »
Thanks.
With no other information other then being a Dearborn car it is less then likely that the low mount (thermactor equipped) is original . If it was a San Jose car it would be the other way around .If it had thermactor you would have the low mount (smog pump mounts above).
Offline bazza
« Reply #3 on: December 16, 2015, 07:18:57 PM »
That was my guess as well.  Now I need to try and source just about everything under the hood. Any ideas on what sort of compressor it would have had??
« Reply #4 on: December 16, 2015, 08:46:46 PM »
........... Any ideas on what sort of compressor it would have had??
Cast steel painted semi-gloss black not the aluminum style
Online krelboyne
« Reply #5 on: December 16, 2015, 10:55:56 PM »
Tecumseh brand compressor is the cast iron one.
The less common York, was cast aluminum.
Offline bazza
« Reply #6 on: December 16, 2015, 11:04:39 PM »
Thanks for the info, that will get me started on collecting the parts.
Were they dated?? Could I get one from a later year- car line, and still be correct??
« Reply #7 on: December 17, 2015, 07:31:41 PM »
Believe you'll find that the dealer installed and in general service replacements were the aluminum versions. Might be due to the fact they were not going to rust on the shelves add weighed allot less for handling and shipping purposes
As "krelboyne" wrote the aluminum pumps are referred to as York pumps which is somewhat odd since the main cases are cast with Lester the supplier and were supplied (well at least some of the time) by Borg Warner  at least 67-68 but again there were, most of the time, over the counter units
Unless you have one of the rivet or bolt on labels from your application - no other applications will have different part/engineering numbers and dates if your going that far.
Will leave the dating question "krelboyne" since I know he's been looking at these details this last week
« Last Edit: December 17, 2015, 08:47:18 PM by J_Speegle »
« Reply #8 on: December 17, 2015, 08:45:55 PM »
As for pictures I think this is one of those times were an Assembly Manual would be well worth getting. It will have all the fan belt routing, hardware and brackets shown in exploded views
Below at some pictures of course each example has been modified or maintained through the years so don't assume anything is factory correct by itself. Check or ask to confirm ;)
Hope these helps
Offline bazza
« Reply #9 on: December 18, 2015, 08:53:56 PM »
Thanks again. That does help.
Thats 2 questions, 500 to go.  :)
